Revo 2.5r Cutting Out At Low Speed
FL
When ever I start it I have to give it a lot of throttle to get it to turn over. Then once I get it running it will run fine, once i let off the throttle and let it stop after about three seconds the engine will cut out and I will have to use the easy start and get it running again. Does anyone know what that could be? Is it the low speed needle? If so or even it it isn't can you ttell me where to find this needle and whatever needle to tell me to turn! Thanks I am new at this!!
RE: Revo 2.5r Cutting Out At Low Speed
It sound's like your low end needle.if you start you engine sqeeze the fuel line about a inch from the carby .you wan't it to run for about 4 seconds before stalling if run's longer you are to rich on the low end.
