Heat protection?
Heat protection?
Hi
Is there anything that I would be able to put on the Fuel tuning for my T-MAXX3.3 cause the pressure line touchest the header and the thing that traxxas already put there is melting. is there anything else that I can put there instead?
thanks
Xtfreak2
thanks
Xtfreak2
NC
RE: Heat protection?
the fuel line should be fine touching the header. mine is and i haven't had any problems. if you wanna be safe get some of this...
http://www3.towerhobbies.com/cgi-bin...?&I=LXMHW7&P=7
PA
I dont think it will melt I was trying to melt 2 pieces together and the wouldent.... I had my sauntering gun up to it (red hot) and wouldent even burn....
CA
it sounds like your engine is really hot. the pressure line is silicone and is very heat resistant. it takes a lot to melt. richen you car just a little. maybe that will do something.
ON, CANADA
just keep the line a few cm's away from the head.....I've never had a fuel line melt on me yet but I have melted 2 of those heat shield things..
FL
I already have one of these on and this is the thing that is melting, Now I assume that its supposed to PREVENT the pressure line from melting? Is there any "heat resistant" tape that I can buy at a Home depot?
