Revo Problem!!!
Revo Problem!!!
Hello,
I have a Revo 2.5 with a 3.3 motor and drivetrain, recently I have installed the FOC kit, new slipper clutch, primary clutch, and I have checked and rechecked everything on it and I can no figure out what is wrong. What it is doing is after i get the motor started and get ready to drive I can rev the motor but the revo doesn't go, and as far as hooking up everything i have done it all to the instructions based off of the Traxxas website. Any one have any ideas of what it could be?
Also I just purchased an Integy clutch that i have not yet installed but was wondering if they are any good?
Thank you in advance!
RE: Revo Problem!!!
Yea the spur gear and everything heading into the transmission works great! and i checked all drive shafts and both diffs. and those seem to be fine also...
RE: Revo Problem!!!
I have no idea i can check on that, I was also wondering if when you spin the spur gear shouldn't it also spin the center diff. in the tranny?
RE: Revo Problem!!!
I couldn't find any thing that said there was a one way bearing in the tranny. I just took it outside and started up reved up but still didn't go so im going back through it again... axles, diffs, tranny, clutches, and motor.... if you have any other suggestions please let me know!!!
Thanks again in advance!
RE: Revo Problem!!!
well it first did it when i had the reverse still in it, and then i replaced it with FOC and it is still doing it... yea well i have it torn down to the bare frame right now so it will be mid afternnon before i get it back together again... haha...
