engine drop-in
FL
engine drop-in
Is a 2.5(not the R version) a direct drop-in to a .15 model? I might be able to get a 2.5 from a friend running or not for $10, it was given to him. I need to know if that would be a direct drop-in into my .15 t-maxx.
Thanks.
Thanks.
CA
RE: engine drop-in
The exaust manifold is different, and throtle linkage. The tranny is the same, motor mount,clutch bell are all the same. Flywheel is the same but has a different nut on it.
Easy start or pull is different.
Good luck.
Good luck.
GA
RE: engine drop-in
It is NOT a direct drop in. You can get a conversion kit from Traxxas, Tower or on e-bay - they're usually around $25 I think. That will take care of everything except the starter system.
I've done it too and contrary to what crazy8t said. I thought the performance increase was worth the effort, And no real problems from the upgrade.
If the 2.5 runs then it's worth the $10. If it does not run then, IMHO, it's worth is as a paperweight. Absolutely not worth rebuilding or doing an exchange because you can get them new off e-bay for less than the engine exchange program.
If you want a good engine to put in that truck check out the OS.18 CV-RX(s). That's about as close to a direct drop in hop-up engine as you'll find.
RE: engine drop-in
yes there is a little but i mean they are 100% geared different im shore of it but there is a little increase and like what daveg55 said if it runs hells yes but if it doesnt and it will be a hassle then dont
GA
RE: engine drop-in
ORIGINAL: crazy 8t
RE: engine drop-in
Bute Dave the question was will a 2.5 fit? Thats not the same mount as a 2.6 or 3.3 I know the 15 carb is rotary. Just learning so please tell me.
GA
RE: engine drop-in
ORIGINAL: Edfltchr
http://www3.towerhobbies.com/cgi-bin...?&I=LXDAJ7&P=7
Everything else (except the starting system) will transfer from the Pro.15 to the 2.5/2.5r/3.3 including the motor mount, flywheel and clutch shoes.
You will have to get a pull start or ez-start system (including a new owb) that is compatible with the 2.5/2.5r/3.3 as the one from the Pro.15 will not fit the 2.5/2.5r/3.3 engines.
For the record, anything that fits externally on a 2.5 will also fit the 2.5r AND the 3.3
