question on center diff revo
i have a revo 3.3 with a 2.5 transmision with a forword only kit already in it want center diff what other parts do i need instead of buying kit because i dont need forward only parts
thanks dave
thanks dave
TX
RE: question on center diff revo
well dave, it is dave isn't it? The Center diff comes with the FOC so you will just need to get the rear brake kit. Someone correct me if I am wrong.
yes thats were i found it its just because i added forward only kit already i just want to add center diff for racing so it dont wheelie
uh, the FOC is sold without the center differential.. you can, however, buy the center diff separately and install it.
Strange, i was just looking... I know I bought only one item that had the center diff, FOC and rear brake kit... but doesn't look like they sell them all together. All separate.
TX
I may be wrong here I am not sure. I thought that the center diff kit came with the FOC. I am unaware if the 2.5 tranny is different from the 3.3 tranny. I don't remember reading anything about it. There are some guys on here that will help you out soon I am sure.
TX
[link=http://www.traxxas.com/products/nitro/revo/revo33/trx_revo33_accessories.htm#centerdiff]Here you go.[/link] Scroll down a bit.
Center Differential
The optional center differential can be installed on Revo 2.5R* or 3.3 to help balance the distribution of power to reduce front end lift on acceleration and improve steering responsiveness.
Part #5414
Differential kit, center
(Complete for Revo)
(assembled with 100K oil)
Requires forward-only conversion (included)
Suggested retail price $ 39.00
*Requires short-rear output shaft, part #5416, for use with Revo 2.5R standard chassis.
Part #5416
Gear, differential output
Suggested retail price $ 6.00
Center Differential
Part #5414
(Complete for Revo)
Part #5416
TX
I realized what you were trying to get out of your question and Traxxas does not specify the part number of the output shaft in hte FOC kit but if I had to guess I would say that the outputshafts in the FOC and center diff kit are the same between the 2.5 and 3.3 trannys because they do not specify a different part number for the center diff for the 3.3 and 2.5. It is only one kit. What I am trying to say is that the output shaft you already have is the one they say you need for the center diff. Blaghghg. That was tough. Get the center diff and you do not need anything else...I think.
I regret trying to help on this one. I am confused as hell.[:@] Snoking, nitrovenom, JBCOMP, Hillfinger somebody help this guy so he can save himself 6 bucks!
ORIGINAL: FISH KILLA
Center Differential
Part #5414
(Complete for Revo)
Part #5416
Center Differential
Part #5414
(Complete for Revo)
Part #5416
Looks like he'll need 5416 to put into the c-diff to compensate for the 2.5 chassis. Sounds like the drive shaft will not shorten enough.
the center diff does indeed come with all the parts for the FOC, but the 2.5 tranny case doesn't have the mounts on it for the rear brake kit, so you'll need the rear half of a 3.3 case to use rear breaks, which are the ones you want off road.
FL
If it has a forward only conversion and you want a diff. you just need to buy the diff kit, and some 500,000 weight diff lube, its like cement, but that revo diff just doens't work with anything lighter
so what i undstand is buy just center diff kit only but what is part no for revo 3.3 that does not include forword only kit and the only center diff output shaft part no i found is for revo 2.5 the short one
let me know thanks dave
I have a 2.5 Revo and the stock center diff fit perfectly in mine without having to replace any of the parts in the diff. It will be a very tight fit. but it does fit. You will have to almost walk the tranny back into the chassis in order to reconnect the rear driveshaft, but it all does go back together with some patience. As far as the lube in it goes, thicker is better in the center diff. The lube it comes preloaded with is way too thin for regular use(it will rapidly unload to any tire not on the ground). Good luck.
FL
Our there any pictures or instructions on installing the center diff.... I have a revo that i purchased on here and it has the FOC But i am pretty sure that it doen't have the center diff because of all the wheele's that is does.... Thanks UTUBe??Maybe?
FL
Does this truck have a center diff... It has already FOC... THanks
[link]http://i111.photobucket.com/albums/n160/dylansmac/IMG_3556.jpg[/link]
[link]http://i111.photobucket.com/albums/n160/dylansmac/IMG_3558.jpg[/link]
