Traxxas Monster Truck forum Discuss the Traxxas T-Maxx, E-Maxx, Super-Maxx and all other Traxxas monster trucks in this forum. You may also optionally discuss them in our MT general discussion forum.
Revo 2.5 running oversized wheels/tires
Old 03-19-2008, 01:32 PM
joeyvaz
Default Revo 2.5 running oversized wheels/tires
I just installed Ofna 17mm adapters on my son's Revo. I installed HPI Tremor wheels and Goliath Tires. They are oversized wheels (115mm) so I had to use the Goliath tires. I haven't run them yet because of lousy weather.
Will there be any ill effects of running such big wheels on a 2.5 Revo? Will the drivetrain need to work harder to get these wheels moving and to stop? If the stock engine wears quicker, I don't care. I'll probably upgrade to an
OS .18TM, but I'm more worried about hurting the transmission and diffs.
Any thoughts?
-Joe
Old 03-19-2008, 01:37 PM
mustang-04
mustang-04's Avatar
Default RE: Revo 2.5 running oversized wheels/tires
id think itd be a little harder on the engine and clutch to get those wheels turning, and of course youd be a little slower off the line.
but i dont think they would effect the drivetrain at all, its pretty solid!
2 cents
Old 03-20-2008, 11:21 AM
Beasley1
Beasley1's Avatar
Hey I just saw your ?. I have them on a 3.3 with the picco .26 maxx. I have the Robinson Racing steel spur/clutch bell on it with a M2C aluminum clutch.
Mine is running great. It pulls the wheels up even easier. Just have to have throttle control. It does want to tip in the turns easier so im thinking about getting the sway bar kit. Should help alot.
On the other hand you can run over anything! Its awesome. I would recomend at least getting the steel spur and maybe a MIP clutch at least.
Old 03-20-2008, 11:26 AM
twomanytoys
Just gear up to move the bigger tires.
Old 03-22-2008, 01:07 PM
westly
i have a revo with rb 523 and i just got a set of cen genesis wheels which is huge,do you think i can run it good on my revo for bashing around?
Old 03-22-2008, 01:08 PM
westly
whats the good size gear for doing wheelie,mine 16/38
