robinson racing steel spur gear on a t-maxx
i had purchased a 72 tooth robinson racing spur gear and installed as directions said "remove very little of edge of transmission hex shaft"so i did a little too much and the gear and slipper plates wobble like so bad it rubbed on the battery box. anyone else had this happen to them
RE: robinson racing steel spur gear on a t-maxx
wow, you sure you have your washers in the right places? that sounds odd. i never cut any shaft down with mine. im running a robinson haft though. but i have ran with the stocker without triming anything without problems.
im running the robinson racing spur and have no problems with it. a re you sure that you installed it correctly? heres a pic of mine installed
OH
ORIGINAL: systemlord
What is a hex shaft?
http://www3.towerhobbies.com/cgi-bin...7&I=LXJG99&P=K
CA
ORIGINAL: thesouth1
The shaft the spur is on...AKA the top shaft AKA the 2 speed shaft...
CA
ORIGINAL: saubererik
im putting the forward only conversion on it soon does that replace that shaft?
Yes, you have to get a forward only shaft that has a gear on it, its a really cheap ($10 dollars at Tower) part. I'm not sure if the forward only shaft is the same for all traxxas trucks and buggies? You can either use the existing shaft leftover from tearing apart your tranny and use the hardend aluminum gear, or just buy a new shaft with plastic gear.
so to anwser your ?, no. you need a new topshaft.
CA
ORIGINAL: Nighthawk z450
i beleave he's refering to replacing the "topshaft thats damaged" not the forward only shaft, its 2 different one.
im putting the forward only conversion on it soon does that replace that shaft? [/b]
I'm not sure why you'd need to modify the shaft, but if its bent replace it. I had the problem with the RR spur brushing against the battery box tho. the clearance in that area is quite close. I took off the battery box cover and used a saw and a dremel to cut a piece off, been working perfect since!!
CA
ok thanks everyone the foc kit will stop the bucking at idle too right
CA
ORIGINAL: jasytosy
when you buy a steel spur gear do you need a hardened steel clutch bell?
MI
The Topshaft is TRA4992, BTW, assuming you have a 2.5 maxx. It is different on the 3.3.
