Traxxas Monster Truck forum Discuss the Traxxas T-Maxx, E-Maxx, Super-Maxx and all other Traxxas monster trucks in this forum. You may also optionally discuss them in our MT general discussion forum.
picco jato problems
Reply
Old 04-15-2008, 09:57 AM
jasytosy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default picco jato problems
when i allow my jato to shift gear or just stay in 2nd gear it shreds its spur gear, when i take out the 2nd speed and just have the one speed the spur gear is fine no damage at all, it is all alligned properly witht he proper mesh.
i do have a picco .26 in it so should i just get the single speed conversion.
jasytosy is offline
Old 04-15-2008, 01:05 PM
Mspeed
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: picco jato problems
Have you tried a 40 revo spur with a 20 revo clutch bell, they are alot harder to shred. The pitch is better on those gears for the more torquey motors. And since you have a .26 you should be able to push that high of a gear with all the bottom end you got. In the end, I would think you will shred the internal 1st and 2nd gears from all the torque that motor puts out anyways, unless you get the bronze tranny gears. I do not suggest going with metal spurs, cause one thing gets stuck in that spur and it will eat up other parts.
Mspeed is offline
Old 04-16-2008, 06:35 AM
jasytosy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i cant shift my engine enough to fit a revo gearing
jasytosy is offline
Old 04-16-2008, 06:41 AM
RCCanuck
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I''d go with the robinson racing spur/cb set up for the jato....either that or your slipper is too tight so when you shift into 2nd it is just too much for the spur[&:]
RCCanuck is offline
Old 04-16-2008, 07:16 AM
jasytosy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
how tight do you reccomend i have it on 3/4 turns out
jasytosy is offline
Old 04-16-2008, 07:23 AM
RCCanuck
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well actually that is way looser than i run mine on my Tmaxx.....I know the manual for the Maxx says all the way tight then 1/4 turn backout again....
RCCanuck is offline
Old 04-16-2008, 12:36 PM
Mspeed
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You should be able to fit a Revo 20 cb with a 40 revo spur with out problems. You have to use the complete revo spur and cb together cause the pitch is different than the jato and tmaxx stuff. The pitch on the revo stuff gives you alot more strength and will give you more gearing up top which is what you need for that big motor you got. You got alot of bottom end but not as much top end, the revo stuff will help you out there. That picco is going to put alot of stress on your tranny gears no matter what you do, if you run the slipper loose it will just slipp all over and burn up, but help save the driveline, if you run it tight it will strip out trannys left and right. I would recomend the bronze tranny gears so you can set the slipp correctly.
Mspeed is offline
Old 04-16-2008, 12:38 PM
Mspeed
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If the picco wont let you use the revo stuff, my next pick would be just go steel spur on your jato, eventhough its something I wouldnt normally do.
Mspeed is offline
Old 04-28-2008, 06:56 PM
MiamizFinest
MiamizFinest's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dam your still haveing problems with that picco jato? man i would have thought u sold that thing a while ago
i got rid of that head ace real quick
MiamizFinest is offline
Contact Us Archive Advertising Cookie Policy
