so how are the motorsaver airfilters?
because i just bought one from tower....and i will it make my engine run leaner also how much tuning did yall have to do just wondering..................................i know i will have to tune it a lil.
RE: so how are the motorsaver airfilters?
they say you will need to richen a bit since you are flowing more air. i have one and i like it. i always retune whenever i run the car so when i installed mine i just made my necessary adjustments like always. it's a nice filter though, WAY better than the stock trx one.
ORIGINAL: Soothsayerman
I love it. One of the best/cheapest upgrades you can do.
Indeed It is one of the better, if not thee best upgrades that can be done. Helps for much better engine breathing....[8D]
ya i ordered 1 yesterday shuld be here friday........also alluminum bulkheafds - they broke. new shock tower and 1 shock .....lol
yeh got that and some pre foam for motorsaver along w/ some airfilter oil and some fuel line and new fuel tank.....cracked mine bad.
yeah........[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXHWU0&P=ML]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXHWU0&P=ML[/link]
so VXL hows that REVO been running?
IN
These air filters require a lot of air filter oil. I also recomend zip ties around the base of the air filter because it falls off easily even with the metal clip.
TX
My stock neck is dead, spur gear chewed it up. I need to order a new one. I use that robinson racing slipper plate and it makes the spur stick out further.
Try ordering one for the Savage. That's meant for a big block so its a lot bigger. I borrowed my bro's for a little whille to test it out. It even fit on my smallblock. Here's what my filter looks like.
MI
It's great. A day at the races in the dustiest tracks I had ran at, I didn't need to change the filter. Actually, it still had a lot of good clear area.
And I just used the neck that came with it. It doesn't rest on the spur or anything, and the neck grips the engine so tight that you don't even need zip ties.
NM
ORIGINAL: [email protected]
Of course, its good to hear that things are a-ok at the moment....hopefully nothing of any big proportions will crop up...
Try an HPI Savage filter, its much better quality than the Motorsaver and cheaper. Imo there is no better RTR or upgrade filter than the one from the Savage, high volume and dual stage[8D] $6 bucks compared to Motorsaver at $15+..
