how to remove the flywheel (t-maxx 2.5)
CA
RE: how to remove the flywheel (t-maxx 2.5)
you did take off the clutchbell right? and the shoes? and the lock nut? after that, you just pry the flywheel from the back of the crankcase...
taking the lock nut off the crankshaft can be tricky (not really)...just use something to lock the flywheel in place, and then use an 8mm (i think) driver to screw the nut off..easy
Nevermind i had to use a flat screw driver to get it of. wow i feel stupid.
Now since i am getting a 2.5R as a replacement motor. what clutch and flywheel combo do you guys recommend?I am looking for under $40 for the clutch set.
