If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 19 of 19
  1. #1
    Join Date
    Mar 2007
    springfield, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    should this be happening?
    i just recieved my trx 2.5 engine back from traxxas, (they replaced the piston and sleeve by the way) and i just got done with the break in and i just got brought my truck in and there is a stream of smoke comming from the cooling head of my engine. the grass is dry and i didnt drive through any water or anything. what is causing the smoke? is it normal? plz help me.
    Trnt_West
  2. #2
    Danju's Avatar
    Join Date
    Feb 2007
    thousand oaks, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: should this be happening?
    its running lean....richen it out a bit...or ive heard that sometimes residual oil (WD-40) evaporates from the cooling head when the engine is hot.
  3. #3
    MJAsony2305@aol.com's Avatar
    Join Date
    Dec 2007
    Dallas, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    tighten the plug also.
    thats your 2.5 cents but this is my 3.3 cents.
    rustler 3.3 come on try me.
  4. #4
    Join Date
    Mar 2007
    springfield, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    at first i thought i was running it a little to lean but i checked and it was still 4 turns out and i even richend it up to 4 and a half turns just to make sure it wasnt running lean, and it still had a small stream of smoke.[]
    Trnt_West
  5. #5
    Join Date
    Dec 2007
    Dallas, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    TIGHTEN THat plug man even that can make it run lean and what model is it? also check your low speed needle it could be that too.
  6. #6
    Join Date
    Mar 2007
    springfield, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ok, ill try that, but its a tmaxx 2.5
    Trnt_West
  7. #7
    Join Date
    Dec 2007
    Dallas, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    yeah i would also check for an airleak and make sure the cooling head is tightened all the way. and also check the carb and fuel lines along w/ the exhaust line, o rings, and coupler, also i would check the fuel tank lid.
  8. #8
    Join Date
    Mar 2007
    springfield, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ok thank you, but one more question. whats the best way to check for leaks in all of these places? ..exhaust, carb, fuel line, tank, etc..
    Trnt_West
  9. #9
    Join Date
    Nov 2007
    hervey bay, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Air compressor while engine is running blow over it, LOL not the air filter dah, if its got a leak it'll likely stall , and its not normanl for ANY nitro engine to smoke, other than exhaust smoke, check ya clutch isnt fried or frying, and that oil or like someone said WD 40 or RP7 whatever one you use hassnt clagged up with grit on the block, usually that is a sign the heads to hot via lean running, but as you have richened it , it must be something else, either something rubbing or cooking, lol clutch or gunk !
  10. #10
    Join Date
    Dec 2007
    Dallas, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    replace all o-rings and couplers and then take then engine off and rub it down with a tooth brush dipped in soapy water(make sure to plug the exhaust hole and carb whole...oh yeah take the carb off and put copper RTV sealant around the screws NOT needles just the screws) and after the soapy water just blow in the fuel line going to the carb or blow into the carb whole if carb removed and see where bubbles form the put copper RTV sealant around those areas.,...or you can just seal the whole thing with sealant to be on the safe side.
  11. #11
    Join Date
    Mar 2007
    springfield, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ok well thank you both for your help. its good to know that there are actually nice people on here, unlike other forums.
    Trnt_West
  12. #12
    Join Date
    Dec 2007
    Dallas, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    lol no problem we have all been there through the hell of our R/C not working.
  13. #13
    youwish16's Avatar
    Join Date
    Jun 2006
    Milledgeville, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    BUY A TEMP GAUGE! lol
    Losi 8ight,Precirotate 3 Port Modified Engine,Avid Bearings,Dynamite,Sprektrum Radio,Ace Servos,Fastlane Graphix,Stickman RC
  14. #14
    matts6887's Avatar
    Join Date
    Mar 2008
    scottsdale, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Like the above mentioned; if u have it set that rich and it it still seems like its running hot; then more than likely u do have a air leak somewhere. Check the o-rings in the carb, the fuel tank and lines for possible pinholes that u cant see, and u also might want to take the backplate gasket off to check/inspect the backplate gasket for any possible nics or tears which indeed can and a lot of times will cause a air leak by allowing air to seep in....
    \"If U havent broken anything....U arent driving it hard enough\"
  15. #15
    Join Date
    Mar 2007
    springfield, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ok ill check for all of hese things, and does traxxas have a pack of like all the o rings and gaskets that i can buy?
    Trnt_West
  16. #16
    Join Date
    Dec 2007
    Dallas, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    yessir they do its on towerhobbies.com
  17. #17
    matts6887's Avatar
    Join Date
    Mar 2008
    scottsdale, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i believe they do, but I'm not totally sure of the part # off hand. If I have a chance I will look it up and post it in here for ya; otherwise I'm sure someone else might get to doing that before I do.
  18. #18
    Join Date
    Mar 2007
    springfield, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ok, and once again thank you all.
    Trnt_West
  19. #19
    matts6887's Avatar
    Join Date
    Mar 2008
    scottsdale, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: trnt_west
    Not a problem! Any further questions; just ask away and someone will be glad to help!! [8D]
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
