Carb troubles. Pictures included
NJ
My os .18 mwas not reaching its top potenial so i was a little mad. With a little pondering I checked to see if the carb was opening all they way. It wasnt.
I at first thought it was my radio because i was using the losi micro t one. But!! I brought it up to my workbench and with a little messin around i have a solution
Its the dust boot cover on the lsn. I have no idea why its holding it back but it is. The blue one from the 3.3 does the same thing on that engine to.
Anyone got any ideas? i dont wanna drive in the dirt without a dust cover on that.
TN
RE: Carb troubles. Pictures included
Two tips for right now.
1- clean that motor up very nice and clean
2- replace that spur
Looks to me like your servo doesn't have enough torque to open the carb up with the dust boot. Maybe try a diffrent servo?
NJ
Lol yeah i'm gonna do that today. Is the cooling head good to rinse under water? And the carb to? It will be off the engine off course.
And the servo is the stock one [:@]
ORIGINAL: sunco1
ORIGINAL: ENZO7
Y get a new spur? Mine looks like that, it runs fine...
when i clean my engine.
i put carb in the alcohol for a while...and then clean it...
but there were still some kinda sand or stuff in the carb, so i used water with jet-head to clean the inside(i dunt have air gun)
after that...back to alcohol....
then fire it up rite after i put everything together...let it run for like 10 mins...
guess all the water already gone
NJ
yeah but i dont prefer that spur gear. Its got 36 teeth I stripped a stock one and thats all i had. So until i get a 38 tooth i'll use that one.
Is the carb ok st spray with brake cleaner instead of the alcohol?
MA
Your carburetor might be slightly out of alignment which causes a binding and does not allow full throttle. [link]http://www.traxxas.com/PDF-Library/5207RINST.pdf[/link]
ORIGINAL: sunco1
TX
Dont use brake cleaner, the stuff does work fine, but the crap is toxic and is not friendly to plastic. Denatured alcohol is a better solution. my .02 cnts.
ORIGINAL: Soothsayerman
use the non-chlorinated stuff
that's all stuff like
nitro-blaster is
still, the alcohol is
probably safer
ORIGINAL: sunco1
Matt what are you talking about? Your car runs perfect
NJ
o lol no not you matts6887.
Revocrazy7's name is matt. He is my neighbor. And idk why he says he has the same problem when his car runs perfecto
looooooooooooooooooooooooooooool!!!!! yea i am matt haha!! but yea i have that carb problum to but ajusted the linkege for about an hour and kinda fixed it. but its still kinda there. anyway its not that bad!!! oh and a BOO!!haha im board.
NJ
No idk how to explain how its running. I'll try to get it on video for you guys. And matt a need to borrow your temp gauge because mine is messed up i think... [:'(]
Loosen up the pinch bolt and turn the carb Clockwise a mm or two and it should fully open the carb again. Then just tighten the pinchbolt in place.
