If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 22 of 22
  1. #1
    Join Date
    Mar 2008
    Winnipeg, MB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Revo 3.3 Idle Problem
    My revo idle's fine when its first started, but after a tank of fuel it starts to rev up and down. Why is it doing this? I've tried playing with both the fuel trim and low idle trim, but increasing the throttle trim seems to be the only thing that steadies it. Even then its changes after time. I'm sure I'm doing something wrong and would appreciate some advise.
    SureToCrash
  2. #2
    Join Date
    Apr 2006
    Edmonton, AB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Revo 3.3 Idle Problem
    sounds like you have an air leak[:@] Im going through one of those myself. What i hear around here is spray soapy water over the hoses and carb/engine then take the hose off the tank and blow into it. Do you see any residue around the carb or flywheel?
  3. #3
    Join Date
    Feb 2006
    Orange County, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    This seems to be a common problem with the TRX 3.3 engine, I have seen it in many other posts. Could be the front main bearing or seal around carb and/or your EZ-start back plate. Do what equlizer said, then you know where the leak is coming from.
    UE SuperMaxx 1/8th Monster Truck* Custom Duratrax Vendetta Mamba 25 Motor 5400kv Impulse 3S1P 11.1v 950mAH 25C
  4. #4
    Join Date
    Mar 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks equilizer
    I will look into it. Will I ever get this thing to run perfect for just one day.[&:]
    SureToCrash
  5. #5
    matts6887's Avatar
    Join Date
    Mar 2008
    scottsdale, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: equlizer
    From the sounds of it, I would say u are definately right. Definately sounds like a air leak to me as well. Because whenever the idle surges up and down like that as u are describing, that is definately a classic telltale sign of a air leak.
    \"If U havent broken anything....U arent driving it hard enough\"
  6. #6
    Join Date
    Feb 2007
    , VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My guess if its a leak, its your front bearing.
    75% driver/50% set up/-25% vehicle=My kind of race.
    Knowledge is power/knowing what to do with it=win
  7. #7
    Join Date
    Feb 2006
    Orange County, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Mspeed
    Where ever the air leak is its a big one to cause surging like that, I've seen this in full size cars not nitro engines though.
  8. #8
    Join Date
    Sep 2007
    noyb
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i disagree on the air leak
    if the air leak were bad enough to cause the surging you are describing then
    imo, there would be symptoms from the time the engine started , not just after it warms up
    although i could see the symptoms getting worse with heat i just don't see going from no symptoms
    to full blown big air leak after the engine warms
    i think that you have a tuning problem
    read this link from the late ron paris, he talks about what i believe is your problem in the
    carb needle balance section near the top of the link
    http://www.nitroreview.com/hintstips...ngTechTips.pdf
    two kinds of people i never believe - fanboys and haters
    they never tell the whole truth
  9. #9
    Join Date
    Feb 2006
    Orange County, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If there was a small crack in the block it would get worse with heat expansion. When my brother decided to retire his TRX 2.5 engine, after warm-up it would lose wheelie capability because when the engine was cold the piston seal was tighter. You know 9 out of 10 mechanic's would diagnose surging as an intake air leak, I think we should all start the process of elimination here and not skip the obvious signs.
  10. #10
    Join Date
    Nov 2007
    hervey bay, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just a lean bottom end needle will cause it to surge at idle, whats with all the grim posts have you tried to re-tune it again ?
  11. #11
    Join Date
    Sep 2007
    noyb
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    the key things you said were "get worse" and "obvious signs"
    get worse implies that there are symptoms to begin with and he says there are not
    and with nitro rc's (especially with - no offense intended - newbs) tuning is the most obvious problem
    this is not a 1:1 car so, while there are similarities, there is very little direct translation
    using your example, yes a surging in 1:1 engines strongly indicates an intake air leak
    but
    it's also highly unlikely that the 1:1 owner was out there adjusting the engines carb settings
    sure there are things that happen that could cause his symptoms - like a cracked block
    but that sure is...well...less than obvious
    i still think this is a tuning issue
    reset the carb to factory settings and retune it
  12. #12
    Join Date
    Mar 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for all the advise peeps.
    I haven't had a chance to run it yet to check for air leaks. Damn work.
    I really believe its a tuning issue because i'm a newb at this. I have a rc sloutions roll cage, so I doubt I craked the block. My fuel lines are likewise protected. I will check for the air leak but have not noticed any fuel or oil coming out of the front bearing. As I mentioned, playing with the throttle trim will usually steady it for a while, then its off again.[:@]
    I put a fuel filter on the gas line and I'm going to clean it today. Would a dirty fuel filter cause such a problem? But then again, why would it run fine when first started if it was the fliter. Ansewered my own question I guess.
    Thanks for all the great tips
    Off work at 5 and will be testing then.
    Will keep you posted.
    SureToCrash
  13. #13
    Join Date
    Feb 2007
    , VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have had great success with my 3.3's in the past, but unfortuntly I have finially run into a not so great one. Usually it just takes time to learn how to tune, but if you get one of these problematic engines, then your in for a treat if its your first nitro experience. I am starting to think the new batch of 3.3's with that new head on them might have some issues with them, but well see. Tune and tune some more then let us know and go from there.
  14. #14
    GreenRacer's Avatar
    Join Date
    Jul 2005
    , TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It could be the stock carburetor. The block is aluminum the carb is composite. When the block gets nice and hot it can expand larger than the o-ring(s) can compensate for because the carburetor does not expand with heat. One way to remedy this is to get some red automotive RTV silicone and put a THIN layer around the seam to quell any air leaks, or you could get a new seal set. http://www3.towerhobbies.com/cgi-bin...?&I=LXDGB6&P=7
    I'm not saying this definitely is the problem but it sounds like it considering it only surges when it's heated up and the fix is cheap so you might want to try this.
    Alternatively you could buy a better carburetor that is made of aluminum, I've heard doing this makes the engine run like a beast without tuning problems.
  15. #15
    Join Date
    Mar 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well, it turns out my engine was simply overheating. Re-reading the owners manual can pay off from time to time.
    While waiting for the battery to charge, I read that overheating will cause fluctuation, so I richend the fuel a quater turn and there you have it. It was even hotter outside tonight than the last time I ran it, but the adjustment worked. I guess when I was trying to adjust it the other day, it was already overheated so naturally I wouldn't matter what I did.
    Alas, no more catwalk power however.[]
    Thanks again for all the tips and help. If this doesn't fix it in the future, I'll know what to look at now.
    Cheers
    SureToCrash
  16. #16
    Join Date
    Feb 2006
    Orange County, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Glad to hear you figured it out.
  17. #17
    GreenRacer's Avatar
    Join Date
    Jul 2005
    , TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yeah, always best when it doesn't cost you money to remedy the problem. [sm=thumbs_up.gif]
  18. #18
    Join Date
    Sep 2007
    noyb
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    you may have fixed your problem - which is good
    but it still sounds like the engine is out of tune - which is not so good
    reread the manual and the paris racing link i posted
    reset the needles to factory and tune the engine per those instructions
    i think you'll find that you regain some of that lost power
    and still keep from the overheating/surging issues you had
    tuning is a process, not a hit and miss turning the needles 1/4 turn this way or that
    learn to tune properly and you'll get better performance and a lot more satisfaction from the hobby
  19. #19
    Join Date
    Mar 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I actually did reset the low speed idle to factory settings and then adjusted it after a few runs. I also leaned out the fuel towards the end of my runs and recovered most of my previous power, but not all. When it pinched the gas line, it turned off in exactly 3 seconds, which is according to the book near perfect tunning. I know I could of leaned it more, but keeping my engine in good condition is more important than catwalking to me.
    I should also note that I drilled holes in the windshield and side windows on the body cover, and that may be attributing to my engine running cooler. I will testing how far I can safely lean it today.
    SureToCrash
  20. #20
    Join Date
    Sep 2008
    oxford, NS, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    dsd
  21. #21
    Join Date
    Mar 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    dsd to you to.[sm=72_72.gif]
    Don't know what it means but cheers all the same.
  22. #22
    Join Date
    Jul 2008
    Akron, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: SureToCrash
    dsd!! what the fock does that mean?!
    TMaxx 2.5r, Jato 3.3, Revo BB coming soon!
    Drive it like you stole it! AIM-FastDriver2469- IM Me!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
