o.s .18tm
FL
o.s .18tm
finally done breaking it in. it freakin rips. and its still rich i think. temps hit 300 once and 295. drove it in lik a circle at half throttle and the were back down to 260. i have a more than healthy cloud of smoke
OK
RE: o.s .18tm
every o.s. engine i have had has run hot like that. i think its because they have a really tight pinch, which is also probably why they last forever and are very durable.
AB, CANADA
RE: o.s .18tm
My 18tm seems to like 250-260 but there are too many variables that can change this. A fellow I know had an 18tm and it liked 290-300 with no problem.
RE: o.s .18tm
You shouldnt actually judge your tuning on tempature only, there are alot of factors that apply here. You have you Glow Plug, Altitude and nitro. To really tell how your tuning is, just make sure that your pipe is putting out a small stream of smoke at WOT.
RE: o.s .18tm
i'd run traxxas fuel if you are really concerned about temps. the max perfermance will be very slightly less but will be more than made-up for in how lean you can run it without overheating.
MB, CANADA
RE: o.s .18tm
also make sure your header gasket is sealed correctly, and that your useing a tight spring, that will also help bring the temps down. i have an o.s. .21tm and a bent exhaust hanger, and a drilled out stocker pipe. and sometimes the pipe will pull the header slightly out of position, causeing the header gasket to come out of place slightly, in turn leading the motor to run hot. i hate that setup.
RE: o.s .18tm
i would not go leaner. if you are alreayd hitting the 290-300 range, but still have a good amount of exhaust, i would just keep running it that way. over time, it will start to run a little cooler since o.s. engines really start to run good after about 3/4-1 gallon.
FL
RE: o.s .18tm
ok. i leaned out the low and lik a 16th of a turn or something makes huge diff on acceleration. gotta do the same for the mid. but my tranny wont shift so i hav to pull it apart to find that dang screw
MA
RE: o.s .18tm
Dont touch the mid needle. Just the hsn, lsn and idle. As the sleeve and piston wears down the temps will go down. You were probably running real rich on the hsn and
Banned
RE: o.s .18tm
Do you like it ?
l have an OS .20 for my revo in the mail, .2 is 3.41cc, the revo has a 3.3cc engine from traxxas, but l recon the OS is gunna smoke it big time, just going of previous OS experience ! WWWOOOTTT !
FL
RE: o.s .18tm
already hav one.. i think i need a new tranny tho. wont shift to second. ive done everything i can think of.. put a new one of those things in that has the piece of metal pop out and catch the gear...also set it 7 turns out. it catches when i spin it by hand but when in the truck it doesnt shift? HELP!
RE: o.s .18tm
If you can make it shift by spinning it with your hand, it is way to loose, and stuck in second gear. Keep tightening 1/2 turn at a time until it starts shifting close to right, then go in smaller increments to fine tune the shift point. I like the 18tm as well, mine both have lots and lots of fuel through them, 1 in a jato, 1 in an onroad car, and both going strong as ever. Would like to here more about the 21tm though. Bro has one new in box still, and I can't talk him into putting it in his revo or jato until his other motors go out. I wanna see how strong/fast they are.
MB, CANADA
RE: o.s .18tm
ORIGINAL: CBM Racing
