picco.26 with fast idle
MO
i have been dealing with this issue for 2 gallons of BYRONS %20 fuel, "im getting real tired of this engine" i have sealed everything, and replaced the front bearing with a bocca bearing, this engine is air tight, it always starts up real easy, i drive it till it warms up, and then it seems like the idle wants to stay a little high, at the point the clutches start to engage, the pinch test is about 4-5 seconds, you can't idle it down with the idle screw or it will die, ofna says the idle gap should be about a 1/16 gap. so i tried to richen the low speed a little at a time but then it's to rich, each time i adjust the needle i make a couple of passes and then let it idle, it almost wants to idle down a little but when i hammer the throttle you can tell the low speed is way to rich, i put a side pipe because people seem to think it may run better and tune easier, that didnt happen. this thing is a total nightmare from day one, NEVER!!! AGAIN!!! will i purchase a picco, there has got to be something better in that price range
ON, CANADA
RE: picco.26 with fast idle
ok so where is your idle set screw at?......if the low speed is too rich lean it out....then set your idle set screw......never mind what OFNa says set it so it idles the way you want........
MO
the low speed is set a little less than 1/16, if i set the idle much lower it dont want to idle, im sure because its a little rich, i tried to lean it out the low speed very little at a time, and it idles up a little then i try to idle it down but doesnt seem to want to, but if i keep turning the screw it's either one extreme or the other ; it either die or idle fast,there is no in between, i have tuned my buggies and never had a problem, im just about ready to give up on this one
ON, CANADA
ORIGINAL: ELMOBSTER
MA
I ran into this tuning guide a while back read by Ron Paris. It almost 10 years old but still is dead-on. I post this on everyones post who complains about PIcco being a pain.
http://www.rcnitrotalk.com/forum/sho...f3ca89&t=40731
Actually someone shopuld post it here and MOds make it a sticky. If you can read and interpet everything in the article , it should make tuning a breeze.
ORIGINAL: RCCanuck
MO
i have sealed the engine with sensor safe RTV, i have actually tried raising the idle up a little more than normal, then set the low speed to about 3-5 seconds on the pinch test, and when i try to lower the idle it really doesn't come down like you would think, i keep turning it a little at a time and run it and bring it in a listen to it, and when it gets to an area when it sounds like it's going to start to idle a little bit lower, it dies, in order for it to sit and stay running i have to idle it up, and thats when the clutches start to grab, also when its idling i can see little bit of raw fuel spitting out the pipe, i cant find one air leak in this engine, is it possible the tank is not set up for this engine, its not leaking but thats the only thing i haven't changed
MA
Another thing I noticed was my PIcco idles alot faster than my 3.3 ever did. Still does. AS its not taking off or anything just kind of fast.
MO
ORIGINAL: kasarn
ON, CANADA
