Traxxas Monster Truck forum Discuss the Traxxas T-Maxx, E-Maxx, Super-Maxx and all other Traxxas monster trucks in this forum. You may also optionally discuss them in our MT general discussion forum.
High Speed Problem
Old 11-16-2008, 09:00 PM
Soppy
Soppy's Avatar
Default High Speed Problem
So I finally got my truck running again. When I floor it now, as soon as I hit what I believe is the shift point, the car stutters, slows down a bit, and continues on. It does the same thing when I start slowing down (when it would have to shift out of 2nd gear) Could this be something with the clutch?
Old 11-17-2008, 12:01 AM
NitroVenom
NitroVenom's Avatar
Default RE: High Speed Problem
Your probably running to lean or too rich. You sure you had gas when you were runnin it? Because its sounds like my truck when I'm out of gas.
Old 11-19-2008, 05:16 PM
Soppy
Soppy's Avatar
I definitely had gas. I was just running it today and y-day as well. It also tends to stall out when I go from idle to WOT or just when I get back on the gas hard after a turn or something. That I know is not the tranny. Thanks.
Old 11-19-2008, 06:05 PM
t-maxxmaniac
sounds like a lean bogg.....id try richening it up a little and see what happens
Old 11-20-2008, 07:41 PM
Soppy
Soppy's Avatar
It has been cold lately so I have been running it pretty rich. Lots of blue smoke and relatively slow response. The response is probably just the low speed needle though.
Old 11-20-2008, 08:49 PM
PrjctStrtFrce
My Feedback: (10)
PrjctStrtFrce's Avatar
Try leaning out the LSN then and see if that helps out. If you richened up the HSN then the LS setting was altered too, so you have to lean it out a little to stop it from bogging down at low speeds from excessive fuel.
Old 11-21-2008, 11:34 AM
matts6887
matts6887's Avatar
ORIGINAL: t-maxxmaniac
+1!! Im with maxxmaniac here on this one. Try richening it approx. 1/8 turn at a time and see if that helps out any....
Old 11-21-2008, 01:43 PM
donkeymaxx
i agree with the lean bogg.
