will the pro.15 maxx hold up?
My Feedback: (13)
OR
RE: will the pro.15 maxx hold up?
is it running stock width suspension arms, or the widemaxx arms? (two shock positions or four) if it's still narrow, it'll last fine, if it's widened, you'll break them eventually, get the 2.5 version of the driveshafts, you'll need the joints and yokes as they're bigger too
I'm running my CV-R .18 on pro .15 shafts in the front and 2.5 shafts in the back and they've held up for half a gallon so far, and I'm not exactly easy on the thing, and I'm running widemaxx arms all around
ORIGINAL: t-max97
im getting an os.18cv-rx for my stock pro.15, will it strip drive shafts and gears.[:-]
it'll be fine. if there's one thing i like about traxxas it is the fact that i've never had to replace a diff yet. the diffs always seem to be built really strong for the truck. they could make stronger spur gears though[:@]
My Feedback: (9)
GA
off topic, but my t-maxx .15 has a crappy megatech .16 on it i got the truck used but how fast would a stock pro.15 maxx go? and is the .15 a good engine[X(][>:][&:][8D][:@][:'(][][:-][&o]
ORIGINAL: t-max97
ORIGINAL: t-max97
like i said in my last post i does not have the pro .15 on it right now[]
My Feedback: (9)
GA
a lot of people seem to like the 3.3 but not talking about power or torqe is the pro.15 a good engine like is it going to brake after a couple tanks of fuel[&o]
ORIGINAL: t-max97
My Feedback: (13)
OR
the pro .15 will probably outlast a 2.5 or 3.3, it's just not ported to the extremes like a 2.5 or 3.3, it's a little less finiky too... I think they rated it for around 30mph with the pro .15
swapping to a 2.5 or 3.3 takes a fair amount of new parts, the throttle linkage is different ($40 kit there), the exhaust is compltely different (kit price depends on your wallet and your deal finding ability), and in the case of the 3.3, the engine mount is different, isn't it?
the reason people use the CV R .18 in the pro .15 maxx is because everything but the EZ start will bolt up, other than cutting off a couple threads of the crankshaft to use the stock pro .15 clutch nut
ORIGINAL: rangerfredbob
My Feedback: (13)
OR
the pro .15 and 2.5 use the same mount, so that doesn't make any sense... if the 2.5 an 3.3 use the same mount, you don't need one between the pro .15 and 3.3, but that still leaves the throttle linkage and exhaust...
you have to cut the threads off because there are like 3 too many threads on the short shaft version, all you do is put the nut that comes on the engine all the way on then cut the end of the shaft off at the end of the nut with a dremel or a hack saw or something. the threads have to be trimmed because of the depth of the threads in the pro .15 clutch nut.
something with the pro .15 works fine for the beginner, fast enough to be fun, without having it be fast enough to break itself too easily, it's what I started with, I abused that thing... I prefer my RC with the zehoah 23cc... much more fun, less hassle than nitro
