revo 2.5 advanced [problemwont go have done basic checking
ok here is my problem i had a gear go out if you have the traxxus diagrams on the transmission assembly page. you find part 3954 the plastic gearcoming off the transmission right behing the air filter connection.this gear got the teeth striped off of it easy enough i replaced it but now it wont go it seems the motor gear part 1412 spins but the next gear in line part 5215 dosent seem to sping with the motor therefore not spinning the plastic tranny gear is there some pin or something that is missing? another thing when i rasie it up off the ground and slowley apply throttle the wheels will spin very slowely but the motor revs
ON, CANADA
RE: revo 2.5 advanced [problemwont go have done basic checking
your slipper is too loose......tighten it all the way down and then back it off 1/4 turn
ORIGINAL: RCCanuck
ok im stupid whats a slipper if anybody has the parts break down ad can give me the number deatail of the part that would be awsome.would be great to fix it my self.
I don't have a part # but it's pretty simple. The black plastic gear (spur gear) that is right in front of your gas tank will have a nut holding a spring on. That is your slipper clutch adjustment. Tighten it all the way down then loosen it 1/4 of a turn.
wow wow wow
is this on a revo ????
dont
Tighten it all the way down then loosen it 1/4 of a turn that with break stuff
you tighten untill it it only slips a bit
dont
ON, CANADA
ORIGINAL: leroycool1
wow wow wow
dont
wow wow wow
dont
