Noob needs help
WV
Noob needs help
Was running my 3.3 revo today about half throttle when it made a popping noise and engine died. Tried restarting with ez start and engine wouldnt turn over. I know very little about rcs as i just bought this one used last week. Have ran about 3 tanks thru it never really going over half throttle with no problems till today. Any ideas?
RE: Noob needs help
ORIGINAL: tankfarmer123
Tried that, no luck. I should be able to see top of piston when i take plug out right?
RE: Noob needs help
I took head off and im assuming that the top of piston is what i see. Mine has a hole in it!!!?? WTH
FL
RE: Noob needs help
Click on your post, in edit -> All the way over to the right
Click edit, then down at the bottom, left,
Over here it says up load files, click and browse
Down below
Down below
WV
RE: Noob needs help
LOL Bought it from a guy off RCU. He said less than a gallon run through it. He sent bill of sale for a new 3.3 motor purchased in oct. 08. Like i said, ran good for at least 3 tanks of fuel at half throttle or less since i wanted to learn to drive it before i gave it heck. Was running good today then POW. She was dead.
WV
RE: Noob needs help
Oops. Found receipt and the engine was bought in August 08. Do you think traxxas will help me out. If they dont what should i do? Buy new 3.3, rebuild if I can or go to different engine? Thanks all for you help!
RE: Noob needs help
What would i ell them. Hole blown in piston? or should i tear engine clear down to see what else is broken?
What does the head look like? Any divots or scratches?
Well you can get a piston and sleeve for 50 bucks... and a new motor for 110 or somewhere around there so it's a matter of whats still good. If you can save the con rod, crank, and bearings then I would just put a piston and sleeve in it... save yourself 60 bucks.
RE: Noob needs help
All I can say is HOLY MOLY!!!! WHAT THE HECK DID U DO TO THAT THING!!!! [X(] Just kidding...I know it wasnt ur fault; but see the thing is; if u call traxxas and explain to them what happened; Im not sure if they will warranty it because they might try and tell ya it was ur fault; and that without them seeing it in person, they can't make a exact determination without the engine in hand. But on the other hand, they might tell ya just to send it back to them and they will either rebuild it, or replace the entire engine at no charge; Traxxas does have EXCELLENT support; however; in a case like this they may not make a exception; imo it would be up to them to determine what happened......
FL
RE: Noob needs help
Dont even bother, Traxxas has the best costomer service around, it is second to none... give them a call and if they cant help you go from there... simple
