revo with new pico 26 motor help
i just bought a new pico 26 motor for my revo having problems on the throttle after i mount the motor and set the arm in the fork it puts a bind on it and the carb slide wont slid in and out my question is has any one else had this problem and if so whats the fix thanks for any input on this
ON, CANADA
RE: revo with new pico 26 motor help
try adjusting your carb so that the arm pull's straight on the slide....
a throttle return spring help's, IF you don't already have one....
QC, CANADA
Yes, i have this enfine too, and your carb and linkage must be realy in line, because the carb barell will bind easily.
AB, CANADA
mine had this problem. my problem was the slit in the plastic fork that the carb arm goes into was too small. so i took a drill bit and made the slit a little bigger and it worked perfectly.
