Revo 3.3 problems
i just bought a new revo and all was well til the spur gear went out on me i replace it but now when i give it gas it goes but when i let off the engine wants to rev up really high it sounds like its not a good thing at all anybody have a clue what im doing wrong im quite new to this and im not liking whats hapening right now
If it were the fuel that was the problem it would not run well to begin with, not slowly begin to act up.
A few years ago I tested a ½ gallon of fuel that was a couple of months old. My son had left the cap off for at least 2 weeks in my very humid garage (<place>South Florida</place> in the summer months). I used a 2.5R engine with about 4 gallons through it for the test. The fuel out of the bottle ran fine with no apparent signs of any tuning problems for 4 tanks. I then poured in 1 cup of tap water into the bottle of remaining fuel, swirled it around to mix it up and re-tested with the same engine.
After a little tuning, the only difference I could see in engine performance was a loss of power which I assumed was due to the lower nitro content. I used all the remaining fuel without issues. The test was conducted with the same glow plug.
I don’t recommend anyone doing this to their engines but I saw no ill effects.
IMO, fuel gets blamed way too often for tuning issues weather it be related to the carb needle settings or problems with the exhaust/fuel system or engine leaks.
If anyone wants to send me their bad fuel, I will be glad to report back once I use it up…
The engine ran fine for quite a few more gallons after I used the watered down fuel. Don’t remember exactly how long/gallons later. The piston and sleeve eventually needed replaced from what appeared to be normal wear.
I’ve got another experiment ongoing.
A while back a bought a used original 2.5R Revo. It was purchased by the seller when the Revo first hit the market. He was not a good tuner and smoked the original piston. He bought a new engine for it and could not get past the break-in and keep it running. He got discouraged, put it on a shelf in the garage and forgot about it for a couple of years. I bought it and the remaining ½ gallon of original fuel from when he purchased the truck.
The fuel was $14.89 a gallon which matched the original receipt and the date on the label was 02/04, which makes the fuel 6+ years old now.
I ran about 4-5 tanks of it with no problems and decided to see how long it will last. I’m keeping it stored on a shelf in my garage, sealed with the original cap (it was missing the inner plug when I got it). I intend to run a couple of tanks full every year until it is gone or does not run properly. It will take quite a few years to use it up since there is over 1/3 of a gallon remaining.
