signs of bad clutch shoes
IL
What are the signs ?
I took my S maxx out today and noticed the wheels would not stop spinning regardless if adjusted the throttle trim or not; I checked everything else like the carb opening (1mm) and when I open the (carb) throttle and release the trigger seems to be working properly.
The clutch shoes have in between 3/4 and 1 gallon of fuel same with the engine
IL
RE: signs of bad clutch shoes
ORIGINAL: Snook Man
Broken clutch spring and/or shoe(s). Possible bad clutch bell bearings.
How long does it take before you have to replace the plastic clutch shoes (stock) that traxxas sells as far as gallons of fuel; and what is a good brand of clutch shoes(aluminum) that will last longer than the stock plastic ones?
it really depends ive nerer replaced a clutch shoe that is bad ,but i take my engines apart about every week and usually replace the shoes about onec a month is there a screching sound when you roll it is the bearings
when it doesent roll at all it either you trans is stuck just roll it when you get the engine off
or it the bearings and or shoe
