RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   Traxxas Monster Truck forum (http://www.rcuniverse.com/forum/traxxas-monster-truck-forum-251/)
-   -   salvageable transmission or is it shot? (http://www.rcuniverse.com/forum/traxxas-monster-truck-forum-251/11160989-salvageable-transmission-shot.html)
stalefishsk8er 07-19-2012 05:43 AM
hey guys i was running break in tank 2 out of 5 on the new engine i dropped into my t-maxx which is the trx3.3 racing engine and the transmission seized up and won't even turn even if i try to force it by hand. so does anyone know why that might happen in and is there a way i can salvage it and don't have to spend a dime on it? the truck is from 2003 and originally had the trx2.5 engine
<br type="_moz" />
Quickywd01 11-27-2012 09:51 AM
RE: salvageable transmission or is it shot?
If it broke and you need parts how will you fix it for free? Get a job. Depending on your age cut grass, clean up, etc. Problem solved. When you grow up you realize everything revolves around money. Good luck.
tyhatts 11-28-2012 05:29 AM
hahahahah
steed2-inactive 11-28-2012 07:03 AM
first check the lock pins that attach the driveshafts to the output shafts on the transmission. maybe obe backed out and locked against the chassis.
Quickywd01 12-02-2012 11:41 AM
Even though laughing at someones problem is fun, I'm not like that. I was being serious and helpful if they chose to use the advice. BTW a rock can be jammed in the driveshaft area like the other guy said which happened to me before. Hope you figured it out and are back to enjoying your R/C. Ebay has good deals for new parts to help you out some more.
65535 12-02-2012 08:46 PM
I had a rock jam up in the brake disk on my T-Maxx when it was running almost a decade ago, it brought the driveline to a dead halt.
