OS vs TRX
Hi!
After 12 liters of fuel my TRX 2.5R died... [&o] Now i'm thinking on buy a new engine... I'm not very happy with traxxas carb and it seems that the TRX 3.3 have the same carb as the TRX 2.5R... Is the TRX 3.3 so hard to tune as the TRX 2.5R... How is it hold's the tune? I'm a beginner and i'm not a racer, so, anyone can say to me what should be my best choice: TRX 3.3 or OS.18TM? Best regards HARC |
RE: OS vs TRX
both are good but definitely go with the o.s. tm ... much more power and keeps a tune better! enjoy
how were you running the 2.5R that it only lasted you 12 ltrs? were you running lean? my friend did that and it only lasted him 1 gallon. |
RE: OS vs TRX
I have killed TWO trx 3.3 engines. I just replaced the last one with a O.S. .18tm, & I love it.....More power & easier to tune. |
RE: OS vs TRX
and the O.S is cheaper, has an excellent track recored, plenty of people running them to get tech support from, and about the same power as a trx 3.3, direct drop it as well, it uses the same engine mount, pipe and header as the TRX engines, and it is ez start ready, so you can just bolt the ez start on the back and go.
RE: OS vs TRX
This is my story:
I was thinking not to run for a while my REVO 2.5R , so, i used a little more WD40 than usual to prevent any rust… it passed one month and when i take it to run… i’ve noticed the WD40 were out from the front bearing… since that day it begin to be harder than it was to start… i’ve replaced the front bearing and then it starts to run… 3 minutes later it stalls… with so many times i've used the ez-start is motor died… i replaced the ez-start motor for a new one and the engine still not run longer than 3 minutes… it seems that my piston and sleeve were out… i’ve tried to squeeze my sleeve… Wrong!!! I’ve damaged it forever… I dont understand how it really died so soon… my temps never passed 110º C… guess it was me and my beginner knowledge… Now, because of the price of the new piston/sleeve kit i’m thinking on buy a new engine… There’s no need to be faster… I only want one that lasts more time than 2.5R and that is more easy to tune. |
RE: OS vs TRX
ORIGINAL: HARC_PT Hi! After 12 liters of fuel my TRX 2.5R died... [&o] Now i'm thinking on buy a new engine... I'm not very happy with traxxas carb and it seems that the TRX 3.3 have the same carb as the TRX 2.5R... Is the TRX 3.3 so hard to tune as the TRX 2.5R... How is it hold's the tune? I'm a beginner and i'm not a racer, so, anyone can say to me what should be my best choice: TRX 3.3 or OS.18TM? Best regards HARC |
RE: OS vs TRX
I know there's alot of threads around here talking about this, but... Anyone else?
Like i said, my 2.5R sleeve were damaged ... but the remaining parts of the engine are as new... I'll keep them for spares... But... In what engines (3.3 or .18TM) should i be hable to use those good parts of the old engine 2.5R? Can i use the 2.5R header on a .18TM? How many parts and what parts of the 2.5R engine can i use on the .18TM or TRX 3.3? |
RE: OS vs TRX
O.S.
RE: OS vs TRX
You can use all of the external parts (clutch, starter, pipe, mounts, etc) from the 2.5 on either the 3.3 or the TM. I think that the carb from the 2.5 will fit the 3.3 too. Other than that I don't think any internal parts are interchangable. If you want to rebuild the 2.5 you can order parts fairly cheaply off e-bay but even though the rest of the parts may look new they are certainly goint to have some wear so don't assume that they are ok.
If I were you I'd just get a TM. It's a very powerful, reliable engine. |
RE: OS vs TRX
O.S. All the Way!!!!!!I really like mine.:)
RE: OS vs TRX
hey for those that own an OS what are the stock settings for break in supposed to be please? anyone. i did the heat clycle break in but when i was done 1.8 tanks i checked the HSN and it was 4 turns out...?
RE: OS vs TRX
ORIGINAL: danker17 hey for those that own an OS what are the stock settings for break in supposed to be please? anyone. i did the heat clycle break in but when i was done 1.8 tanks i checked the HSN and it was 4 turns out...? |
RE: OS vs TRX
... i need more information!!! :D
RE: OS vs TRX
i have the manual is says the old only like 1/4 throttle for the first tank and then 1/2 for the second and so on:D
RE: OS vs TRX
Does the os feel a lot stronger than the 3.3? I want to upgrade my 3.3, but I don't want to buy the same power you know what I mean? There is nothing wrong with my 3.3, but I want more.
RE: OS vs TRX
ya i was racing on road at my hobby town and i kicked he well tuned 3.3"s butt with my os .18tm but that was just my experience its a little faster yes
RE: OS vs TRX
ORIGINAL: 6speednissan Does the os feel a lot stronger than the 3.3? I want to upgrade my 3.3, but I don't want to buy the same power you know what I mean? There is nothing wrong with my 3.3, but I want more. For more power you need to look at the Picco .26 Maxx or the RB engines or just go to a big block. |
RE: OS vs TRX
... still looking advice for what to choose... :)
RE: OS vs TRX
Picco .26 maxx. Cant go wrong with that. More power = more fun. Its just enough. ;)
RE: OS vs TRX
ORIGINAL: 6speednissan Does the os feel a lot stronger than the 3.3? |
RE: OS vs TRX
Go to youtube an look up some vids with the os 18tm. You'll see that the O.S. has better low end then the 3.3. I've heard stories of O.S. 18tm's that haven't been started for 6 months and still start right up and held the same tune from 6 months before. I Just put the more powerful tz in my truck not to long ago.
RE: OS vs TRX
I was decided to buy me an OS .18TM... but my online store dont have it... only have the TRX 3.3...
People say to me that the 3.3 hold the tune better than is smaller predecessors, can this be thruth? I really am affraid of traxxas 3.3 engines... traxxas engines seem to be hard to tune... at least my 2.5R was... and the 3.3 have the same carb as the 2.5R... i believe that it have good power but the only problem i'm seeing in it is his carb and his hard adjustment... I could buy from another online store the OS .18TM as TOWERHOBBIES... but only my online store can make the shipping without give me problems with customs fees on my country... :D Please be free to (continue) give me your personal opinion! (please avoid to give a dealer opinion) |
RE: OS vs TRX
I can say without a doubt it was the BEST money I have spent on my maxx!!!!
RE: OS vs TRX
ORIGINAL: philthewrench I can say without a doubt it was the BEST money I have spent on my maxx!!!! |
RE: OS vs TRX
Get the OS...only have half a dozen tanks through mine and it's already impressive.
