Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic
Reload this Page >
Unilight afterburner programming
Turbine Clinic Get direct support from the major turbine manufacturer support reps in here.
Old 09-25-2018, 10:14 AM
Dave Fusinato
Default Unilight afterburner programming
Looking for help on how to program the unilight blackafterburner dual module. Just want to do a simple, solid full brightness at or about 80% throttle setting.
Thanks!
Old 09-26-2018, 02:59 PM
aaronforth
aaronforth's Avatar
Thanks!
if I remember correctly this will be a default setting.
otherwise you can change by simply adjusting end points.
there should be a breakdown sheet that came with the unilight system. If not you can download off there site.
