Turbine Clinic Get direct support from the major turbine manufacturer support reps in here.
jetcat 120 wont start
Reply
Old 01-19-2019, 03:33 PM
heyerflyer
My Feedback: (46)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default jetcat 120 wont start
I have a Jetcat 120 that was running great. now it will not start and I am getting a message on GSU saying acceleration delay.
Battery is fine. any ideas?
thanks Steve
heyerflyer is offline
Old 01-20-2019, 12:20 AM
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Steve
A bit more info. Which P-120, gas or Kero start. Has it sat for a while? Disconnect the main fuel line, connect it to a ground tank and in Test Functions use the fuel purge option to pump some fuel, it starts at 0.5v, but use Change Value ( held down) and + to increase it up to 3.0v, leave it there 20 secs and wind back ( using -) to 0.5v
Connect it back up and try a start.
Dave
Dave Wilshere is online now
Old 01-20-2019, 01:35 PM
heyerflyer
My Feedback: (46)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Dave, Converted Kero start. It had been used weekly and I had one flight on it the same day it didn't start.
I will try your suggestion. Thanks Steve
Old 01-20-2019, 10:02 PM
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok, less likely pump unless it’s done a lot of hours. Also do a burner test in the same menu. Holding the change value button should allow you to look up the tail cone and see a bright light. If not the burner has starter to die.
Dave
