Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Engines for Hangar 9 Twin Otter
Reply
Old 07-15-2012, 11:49 AM
korvette
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Engines for Hangar 9 Twin Otter
Of course is electric power easy, clean and fast to start...but there is one dimension missing...and that is sound.
The kit is disigned for .25-.40 2 stroke engine's and that gives good sound...but 2 four strokes are sounding even better.
We fly from grass, so the .25 engines are on the small site..so there should be .40 2 stroke engines...and when you want the same power, the 4 strokes have to be at least .10 bigger.
So the saito .50 should give the same power as the .40 2 strokes only with a far better sound.
Because the Saito engines have the carb. on the back the engine islonger than the 2 stroke and the nacelles would not fit...so we have to make some changes.
The saito .50, .56 , .62 .72 and even the .82 have the same lenght...so for al those engines these changes wil work.
Take a look at the pictures how I made the changes....it looks great...the .62 saito fits great inside the nacelles. I made a short exhaust manifold so the mufflers stays very close to the nacelle. it looks great....sounds great, and because there is enough power I can fly with only half throttle.
I made today a flight of 10 minutes, and the original 200 cc tanks were only half empty...so I can fly at least 15 minutes.
So with a minor work those saito 4 strokes fits perfect.
Good luck,
Kor
ID:	1782160   Click image for larger version
ID:	1782161   Click image for larger version
ID:	1782162   Click image for larger version
ID:	1782163   Click image for larger version
ID:	1782164   Click image for larger version
ID:	1782165   Click image for larger version
ID:	1782166   Click image for larger version
ID:	1782168   Click image for larger version
ID:	1782169   Click image for larger version
ID:	1782170   Click image for larger version
korvette is offline
Old 07-15-2012, 11:53 AM
korvette
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
and a few more pictures
ID:	1782172   Click image for larger version
ID:	1782173   Click image for larger version
ID:	1782174   Click image for larger version
korvette is offline
Old 09-03-2012, 05:07 PM
N.C. Flyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have 2satio 56 fourstroks on mine & flies great
N.C. Flyer is offline
Old 09-06-2012, 08:42 AM
Thomas B
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: korvette
...................................Kor
I have to disagree...when the Twin Otter from H9 is powered by electric, it has a great scale turboprop sound to it....far more representative of a real Twin Otter than any 2 stroke or 4 stroke powered Twin Otter.
Other scale twins (that are not turboprop in full scle) do sound good when powered by gas and glow engines, but if you want a realistic sound from a scale model of a turboprop, it is hard to beat electric.
Thomas B is offline
Old 09-21-2014, 06:54 PM
trumpet20
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have E-Flite power 32 BL using 4S batteries and 13 x 8 APCE props, works great. This is an upgrade from the EFLITE power 25 BL motors.
Empty weight - 11 lbs, 4 ounces, add 2 lbs for the 2 4S LIPO batteries.
trumpet20 is offline
Old 09-26-2014, 09:24 AM
  #31
Thunder Chicken
Thunder Chicken's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What are your Twin Otters coming in at for weight, with which engine choice?
Im scratch building a twotter that is the same size as the H9 (model builder plans, but a fiberglass fuse from an old unknown kit). Im leaning toward electric, but would love to use a pair of FG-11,s or FG-14's. But I fear they will be waaay to heavy! I figure 16# would be the most this plane ought to weigh......
Thunder Chicken is offline
Old 09-26-2014, 02:28 PM
  #32
ronwc
ronwc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had mine for about a year and have flown it quite a bit. It is on 32 size electric, 4 cell 4000mah, 12x6 props, flys perfect, flpas aren't really needed but have them anyway. Not sure on weight, not overly heavy, will get exact weight tromorrow but I would guess 12 lbs RTF wit batteries. I have a lot of glow planes, but this plane is really perfect for the electric setup, even sounds like a turbine when coming on power. Great flying plane, and fairly manueverable.
ronwc is offline
Reply
Display Modes
