Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Ziroli B-25 build pics
Reply
Old 11-14-2012, 04:48 PM
  #51
gblas777
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Ziroli B-25 build pics
had to enlarge the holes in the wing ribs where the wing tubes pass through to get the right dihedral. then cut some holes in the ply plates that go around the wing tube.they kind of work like a centering cam. they will be epoxied to the wing tube and ribsto hold in proper alignment..the holes that were precut put the dihedral almost an 1" off..little extra work but now is all set
ID:	1820357   Click image for larger version
ID:	1820358   Click image for larger version
gblas777 is offline
Old 11-14-2012, 08:06 PM
  #52
jumper666
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is turning into a science project.
gb
jumper666 is offline
Old 12-13-2012, 07:13 AM
  #53
Edwin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Subscribed.
Edwin
Edwin is offline
Old 12-13-2012, 03:06 PM
  #54
gblas777
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
welcome aboard edwin....with the holidays and the extra time at work havent had much time to do much lately..hopefully very soon i will make some good progress
gblas777 is offline
Old 12-13-2012, 03:27 PM
  #55
Edwin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This one is a future project for me. I'm putting together a H9 B-25 as a test bed and practice plane to test out subsystems, new processes, and my new DX18. This is a real handy transmitter. I was able to use servo balance to fix a flaps geometry problem and now I'm using it to sync my engines. Servo balance has 7 way points that you can fine tune to other channels. I'll be tuning each engine individually for best running, then using servo balance to match up rpms without changing the tuning. I used to use a JR matchbox. Then will come the bomb doors and separate bomb drop. Its running with a split power bus for servos and receiver.
Edwin
Edwin is offline
Old 12-17-2012, 04:29 PM
  #56
gblas777
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
back to the build...this aircraft has many complex curves...here is a few wood sheeting pieces wetted and taped into place on the aft lower fuse to conform close to a final shape and will get a final cut when dry....time involved with this part of the process but worth the end results
ID:	1831286   Click image for larger version
gblas777 is offline
Old 12-18-2012, 12:58 PM
  #57
OldScaleGuy
OldScaleGuy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Subscribed. I built one of these shortly after the plans were released from Mr. Ziroli. Great flying plane!
OldScaleGuy is online now
Old 01-21-2013, 09:48 AM
  #58
dalemilam58
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just bought a set of B-25 plans from a fellow club member..I was wondering if the planes came with a parts list...I like to be old fashion and cut my own wood...so I'm needing alist of wood that is used for this build....Thank you
dalemilam58 is offline
