Go Back  RCU Forums > RC Airplanes > Twin & Multi Engine RC Aircraft
Reload this Page >
Ziroli B-25 build pics
Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Old 05-28-2012, 02:35 PM
gblas777
My Feedback: (13)
Default Ziroli B-25 build pics
studying plans and getting some of the pieces sorted out..of course pics wont load
Old 05-28-2012, 02:40 PM
gblas777
My Feedback: (13)
Default RE: Ziroli B-25 build pics
keep getting server error code 500......anyone else getting the same?
Old 05-28-2012, 03:32 PM
jumper666
Subscribed
gb
Old 05-29-2012, 08:17 AM
eagle1945
THIS SITE USED TO WORK JUST FINE TILL THEY FIXED IT!!!!!!!!!!
Old 05-29-2012, 09:19 AM
gblas777
My Feedback: (13)
well what do you know....it worked....maybe...then again maybe not
Old 05-30-2012, 04:11 PM
SIMCO
My Feedback: (33)
SIMCO's Avatar
My parts are threw Customs. WOOHOO
Old 05-30-2012, 10:14 PM
thailazer
thailazer's Avatar
Just replying so I can officially lurk. Good luck with the project!
Old 05-31-2012, 05:38 PM
gblas777
My Feedback: (13)
SEE IF THOSE WORKED
ID:	1767680   Click image for larger version
ID:	1767681   Click image for larger version
Old 05-31-2012, 05:40 PM
gblas777
My Feedback: (13)
well what do you kow.....finally pics uploaded
Old 05-31-2012, 06:43 PM
panhandler
ORIGINAL: thailazer
Dido on the lurking . I have been pondering on theZiroli B-25 for my next build ,,, subscribed . Good luck uploading pics they seem to be hit and miss.
Dan
Old 06-26-2012, 03:38 PM
gblas777
My Feedback: (13)
ok decided it was time to start this B-25 .had a good break from the otter....and got my other home projects done.wife was happy about that!!!! ....here is the initial start on the fuse crutch, not much yet butthings should pick up soon... so far so good..test fit a few of the wing pieces and i dont see any issues yet
ID:	1776027   Click image for larger version
Old 06-26-2012, 04:02 PM
jumper666
I will be looking forward to each post.
For any joining this build not knowing of Gene's previous build which is an award winning Twin Otter: http://www.youtube.com/watch?v=Zd5oQy_0qNY
http://www.youtube.com/watch?v=45X1rJM2vbs
gb
Old 07-18-2012, 03:16 PM
gblas777
My Feedback: (13)
fuse starting to frame up nice
Old 07-18-2012, 03:18 PM
gblas777
My Feedback: (13)
saddle where the horiz stab will sit
Old 07-18-2012, 03:35 PM
gblas777
My Feedback: (13)
here is where the retract air bottle sits.....it is towards the wing trailing edge inside the fuse...i have decided to go with the removeable wing where the the fuse is attached to the wing by lowering the fuse on top...that way i can hide the wing attach bolts which will be accessible through the bombbay doors....all retract air lines and valve will be above the wing...reciever and battery below...decieded to do it that way as it will fit in my truck with the center section attached and will be on all 3 gears and no visible access panel lines. and if needed i can remove the wing center section for maint if needed. i am finding out that this plane will have a lot more equipment stuffed in a smaller package than the otter
ID:	1783377   Click image for larger version
ID:	1783378   Click image for larger version
ID:	1783379   Click image for larger version
Old 07-18-2012, 03:42 PM
gblas777
My Feedback: (13)
the crutch assembly and the aluminum that goes through the wing chord line in this pic is only temporary..it is there for alignment purposes only to keep everything straight..it will be removed once there is more structure added to to hold it firmly in place
Old 07-18-2012, 04:49 PM
jumper666
Coming along nicely.
gb
Old 07-19-2012, 07:01 AM
Pecanpatch
Pecanpatch's Avatar
Whats it gonna be? Gas, Nitro , or ERC?
Old 07-19-2012, 07:26 AM
gblas777
My Feedback: (13)
2 x 30cc gas. looks like the DLE30 will fit nice
Old 07-25-2012, 02:58 PM
gblas777
My Feedback: (13)
this is the cockpit area..ready to start fitting all the details in there..will take some time as cockpit windows are like sunrooms...show a lot..one of the areas i want to stand out
ID:	1785923   Click image for larger version
Old 07-25-2012, 03:09 PM
gblas777
My Feedback: (13)
also got the retract nose gear fitted
ID:	1785925   Click image for larger version
ID:	1785926   Click image for larger version
Old 07-25-2012, 03:11 PM
gblas777
My Feedback: (13)
a few more of nose gear....took some time with the trial fits; but all fits well
ID:	1785936   Click image for larger version
Old 10-16-2012, 05:43 PM
gblas777
My Feedback: (13)
a few build pics
Old 10-16-2012, 05:45 PM
gblas777
My Feedback: (13)
few more
ID:	1811990   Click image for larger version
Old 10-16-2012, 05:47 PM
gblas777
My Feedback: (13)
early wing center section
