Ziroli DC-3
#376
RE: Ziroli DC-3
Here are some pics of the DC-3 I was talking about, unfortunately I wasn't expecting to take any pics that day and all I had was a disposable camera - hence the bad quality.
#377
RE: Ziroli DC-3
Thanks CS,The control surfaces are covered in fabric(Sig Coverall) ,then the fabric was filled with Polybrush,finally they were painted in aluminum dope after the tape and stitching were done.I guess it looks like aluminum in the pics.I think if I build another one I'd build it bigger to accept one of the larger radial engines and add the cargo doors also...Steve
#378
RE: Ziroli DC-3
From what you describe it sounds exactly how the control surfaces on the full scale DC-3 looked to me, covered in fabric and then painted.
As I said before, excellent job - Keep up the good work!
#379
RE: Ziroli DC-3
Hi-
I am applying final scale touches to a 1/8 scale C-47, built in all-composite fiberglass/wood material. Basically this is a Ziroli design, but it has more wingtip washout and a slightly increased wingspan of 150 in. The model is based on "Dakota" L-BW, now exhibited in the flight museum at Oslo airport. This C-47 was built in 1943, was the last one to fly in the Royal Norwegian Air Force and was often used as a VIP transport by the late King Olav V. My engine installation is twin Saito 200Ti inline v-twins. As you can see they will only be visible on the cowling undersides with the cylinder tops slightly protruding. I expext this power outfit will invite a rather conservative throttle use for scale-like flying , as this is one light C-47!
Best regards
Richard Blindheim
Best regards
Richard Blindheim
#381
RE: Ziroli DC-3
Hi Steve-
Yes, you're right. I'm waiting until spring when snow and freezing temperatures have cleared with this one - despite pressures from various friends to get the "Dak" airborne asap !
Haven't weighed it yet, but this should not be a problem as it's constructed light and strong.
Best rgds
Richard
Best rgds
Richard
#384
RE: Ziroli DC-3
Sure. I'm more of a glow than gasoline man anyhow, so I first thought about twin Moki 180 2-strokes but landed on the Saitos for the sound...
Best rgds
Richard
Best rgds
Richard
#385
RE: Ziroli DC-3
Hey Richard I was just admiring your glow plug connectors,I haven't seen them before and was wondering were I might pick up some.I just got my exhaust ring collectors from Keleo and are they ever nice.Kelvin did some mods to accomodate the DC3 and he did it at no extra charge.Great guy to deal with.
#386
RE: Ziroli DC-3
Hi Steve,
Just two regular glow plug remote connectors, connected to one glow socket on the side/underside of each cowling. Can't remember where they came from, but most manufacturers have them. Likely I'll fit some electronic glow units to ensure low and reliable idle and transition.
What are you fitting on your radials?
Rgds
Richard
Rgds
Richard
#387
RE: Ziroli DC-3
Sonictronics system with six leads powered by a 4.8volt nicad.I just got it.Should do the trick,I have to do a bit of soldering to attach the leads and charging plugin etc.......
#388
RE: Ziroli DC-3
Steve-
Good idea. From my experience with the Saito 170, the right lower cylinder sometimes tends to go "sour" and can die without such a system to assist. Had this engine on a Sea Fury first, then on a PT-23 (actually a bashed PT-19), nice sound there out in the open. If one cylinder stopped a power dive would usually bring it back, but this method is not always so practical
BTW, this has likely been discussed before: re cockpit kits for the 1/8 DC-3 - is Dynamic Balsa the best? And which whole body little pilots in say 1950's uniforms would fit?
Richard
Richard
#389
RE: Ziroli DC-3
I had the same sort of flameouts with mine on a Top Flight SR9 with a Saito 170R Richard,It had an onboard system that was progammed to lite up at the low end and if and when I had a cylinder flame out it was dicey especially when your only 50' in the air.It always came back to life when I lite it up though.Yes Dynamic Balsa has the DC3 cockpit kits ,I just scratched mine because theres not much to see in those small windows.My pilots are the ones from Ziroli,they are military but one could change'em to civilan...Steve
ps ...........got my other S-170R in yesterday..
#390
My Feedback: (42)
TX
RE: Ziroli DC-3
Hi Steve
I have followed your building since November 2004. Great looking plane. I still have not started mine yet. I cannot make up my mind
between a DC-3 and a C-47. The DC-3 offers so many different paint schemes and they a beautiful in Airline Colors. I have a set of plans for a British Horsa Glider used during WW2. Some of these were pulled by the C-47 however not many. I have seen a C-47 with a Waco glider in tow. There are two guys in the Sarasota, Florida club which each have this set up. I wanted something different thus the Horsa. Keep us posted as to the progress. Again Great Job.
#391
FL
RE: Ziroli DC-3
What's the word on rivets, Steve? If I missed it in an earlier post, I'm sorry.
Kelvin did a great job- knew he would. I can't wait to see you (well, the plane at least ) in Woodruff.
#392
RE: Ziroli DC-3
I may not use raised rivits,instead I may use something else,I haven't decided yet.I'm still working on the centre section,I'll post some pics soon.
#393
RE: Ziroli DC-3
Just about finished the centre section.I still have to finish installing the onboard glow system and a few other things.The front of the cowl was a bit of work to cover with FM.After a few attempts to cover it in three sections,I ended up using the butt end cut method that layed down with no overlaps.It took 16 panels to cover this area.After the panels were laid down I sanded the area with scotchbrite to fill any panel line gaps and then rubbed down the panel lines to render them almost invisable.Still lots to do...
#394
RE: Ziroli DC-3
My goodness Steve....Its The Look Of The Real Thing....excellent!
Your time investment is paying off. Next time, instead of using the
Scotch Bright to blend diagonally between multiple panels, use
200 wet~dry then work up to 1100.
What overlap are you using on the balance of the fuselage...1/32nd?
#398
RE: Ziroli DC-3
Hi Ruben;have you been working on your DC-3?A good description of how to apply flite metal is on the website www.flitemetal.com ,it gives you a good picture and detailed desciptions of the procedures.I'm basically finished the centre section.All the plumming and wireing is in place ready for testing.Just the final detailing like rivits ,panels etc.Now on to the outboard panels...heres a few pics of the center section installed on the fuse.
#399
RE: Ziroli DC-3
Hi Steve,
Thanks for the nice shots. You have done a marvellous job. Congrats!
Well The DC-3 is still in the hangar unfinished. I have the wings all ready for covering but I want to go the PROSKIN (fiberglass sheeting) way. However, at the moment I am doing a Yellow Aircraft At-6 which is at an advanced stage and I have a Kangaroo turbine trainer at the painters. It is likely that I will embark again on the DC-3 once these two jobs are done.
Yes I know that FLITEMETAL have a description there but since you have undertaken quite a big job of covering the model I am sure that you are an expert at that job now!
Will it still be the Canadian Search & Rescue scheme?
Anyway, again...a nice job indeed.
Reuben
Reuben
#400
RE: Ziroli DC-3
Thanks Ruben;Sounds like you have your hands full also.Yes the experience with flitemetal becomes more rewarding and it becomes easier to apply as time goes on.I think I'll be doing a Spitty in 1/4 scale next with this material.I have the Mick Reeves short kit waiting on the shelf.I'm also thinking of doing a big Piper Navajo 114" span.
I'm still undecided on the colours for my DC3,the original plan was to do it in RCAF colours but I may just go with a civilian/cargo paint scheme.
