Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Ziroli DC-3
Old 11-15-2006, 11:26 PM
  #476
wings2an3
wings2an3's Avatar
Default RE: Ziroli DC-3
Steve,
I am using US 41 with graupner props. Have three successful flights. Flight, #1 was great did not suck up the gear, nor the flaps on landing. Flight #2 gear up, and flap on landing. Flight #3 what can I say, twin 41's at 6700 rpm on a low fly buy, ahhhhhhhhhhh some. Now for my take off expereinces, engines on different channels so one is slaved, tune to with in 100 rpm of each other on low and high throttle. Fly off grass field and when you spool up to taxi the tail comes up fast so you are holding a lot up elevator, and right rudder. As you pick up speed she wants to pull to the left, well you can see your hands are full, in the air it flys great.
ID:	561122   Click image for larger version
ID:	561123   Click image for larger version
ID:	561124   Click image for larger version
ID:	561125   Click image for larger version
ID:	561126   Click image for larger version
Old 11-15-2006, 11:34 PM
  #477
wings2an3
wings2an3's Avatar
some more pics Maiden Day
ID:	561128   Click image for larger version
ID:	561129   Click image for larger version
ID:	561130   Click image for larger version
ID:	561131   Click image for larger version
Old 11-16-2006, 05:00 AM
  #478
bluemagic98
bluemagic98's Avatar
awsome photos i have a colection of them going im going to be working on collecting parts and learning the ins and outs of the air system ussed for the landing gear. I have a lot to do before i finish this thank you for insperation.
Old 11-16-2006, 02:13 PM
  #479
SteveD-RCU
SteveD-RCU's Avatar
Well done man,congats
Old 11-30-2006, 09:52 PM
  #480
PILOT RD
I sure hate to ask a stupid ?? , but how is the outer wing panel jigged up or blocked up during the build/sheeting to ensure proper washout-incidence? I guess I must have missed this someway.
Old 12-01-2006, 08:56 AM
  #481
SteveD-RCU
SteveD-RCU's Avatar
Not a dumb question,cause you need 2-3 degress of washout.Setup your panels on your bench so you have 0 degress at the root and 2-3 degress at the tip .Blockup the outer ribs accordingly so you have your correct washout and proceed from there.Make sure its correct before and during sheeting also because the sheeting should lock in the washout you built in to it.Hope that helps.
Old 12-03-2006, 10:26 PM
  #482
PILOT RD
I just watched a video of Greg Hahn's C-47 from 2005 at Dayton Ohio, it was really awsome. It looked like the plane had some really bad aileron or wing flutter on one side, then he brung it in for a landing. Did anyone else ever see this or have any input on a cause/prevention? Wish Greg would respond to this or tell me my glasses or medication needs to be changed. RD
Old 12-05-2006, 10:06 PM
  #483
PILOT RD
Steve where did you get your tailwheel for your dc3? Roger
Old 12-05-2006, 10:13 PM
  #484
SteveD-RCU
SteveD-RCU's Avatar
It came with the package Roger.Not sure but I think its a Robart type..
Old 12-15-2006, 11:13 PM
  #485
Delta 3
Not to interrupt, but it's been awhile.
You'r plane looks great Steve.
What remote video camera system would you suggest to install a plane that would carry reception on a good distance and still have a good picture
Old 12-24-2006, 09:03 PM
  #486
kevinlmoses
Does any of the Ziroli plan require fiberglass, or does the plan show how to build everything out of wood?
Old 12-25-2006, 08:59 AM
  #487
PILOT RD
The plans show a built up nose, or you can buy the glass one from Nick. (what I did).After talking to Greg Hahn I question the scale outline of the glass one, but its probably better than what I could carve out of wood. The cowlings are not shown built up as far as I remember, which I got a set of glass ones also. RD
Old 05-11-2007, 09:47 PM
  #488
bluemagic98
I was wondering what size props you guy's where ussing on the dc-3 i have 2 older us 41's they both have 2 blade props on them 18X6 on one 18X10 on the other. I was considering 16X10 3 blade or possably a 16X8 3 blade.
Old 05-12-2007, 05:46 AM
  #489
SteveD-RCU
SteveD-RCU's Avatar
I have 16x10 MA props.I hope to testfly mine soon.
Old 05-12-2007, 10:56 AM
  #490
FliteMetal
FliteMetal's Avatar
Send me more images of you with your DC3. Some taken at the field would be even better. If you can
believe it there are still folks who don't think a Flite-Metal covered DC 3 can fly
Old 05-12-2007, 01:42 PM
  #491
SteveD-RCU
SteveD-RCU's Avatar
I can believe it Ed,I'm putting new Fugi 32's with EI in presently and am taking out the used US41's.One has not been running up like it should and I'm getting tired of tinkering with it and I just don't have faith in them so hence the change of power.Plus the Fugi's free up space in the cowl for dummy engines.Steve
Old 05-12-2007, 02:22 PM
  #492
FliteMetal
FliteMetal's Avatar
The Fuji's worked well in Greg Hahn's B-25. They sound a lot better. A pair of
Wms Bros. detailed dummy engines will look great in those cowls. Should be
able to sneak a scale exhaust outlet in there as well.
Old 05-12-2007, 03:59 PM
  #493
SteveD-RCU
SteveD-RCU's Avatar
Ah yes good idea Ed..
Old 05-13-2007, 10:39 PM
  #494
a walk in the park
Pilot RD,
Your glasses are fine, the aileron flutter you saw in the video was caused by a broken DuBro HD servo horn. I've never had that happen before, guess there's a first time for everything.
I promptly installed aluminum horns and she's been solid ever since.
Just finished getting her cleaned up and ready for the flying season, good ol bird!!
gh
Old 05-16-2007, 06:00 AM
  #495
SteveD-RCU
SteveD-RCU's Avatar
Installing the Fugi32EI's now.Man these engines run nice.I also will install the TwinSync from RC Showcase which should be in today..
ID:	685542   Click image for larger version
ID:	685543   Click image for larger version
Old 05-19-2007, 04:04 PM
  #496
old git
Hi Steve,
I only found this thread a week ago, how time flies when you come from behind. I loved the info' and pics you posted. I was amazed at the transformation the aluminium skin produced.
Glad to see that you had a successful flight, wish I could have seen it but I wonder how I would have withstood the suspense.
old git - - - - - - aka John L.
Old 05-20-2007, 06:05 AM
  #497
SteveD-RCU
SteveD-RCU's Avatar
Haven't maidened her yet John, hopefully soon.I'm haveing some glitches that I am having when the engines are running.I am moving the batteries and receivers aft to try and eliminate them.The switches for the batteries where less than a foot away from the port engine accessed through the pilots door and when I run that engine I'm getting the glitches so I'm moving the switches also.
Steve
Old 06-13-2007, 08:28 AM
  #498
SteveD-RCU
SteveD-RCU's Avatar
Installed a Futaba FASST 6 ch in her as per the manufacturers instructions and haven't had a single glitch yet while running the engines in my shop.It seems like 2.4 GHz is the answer in this case.I'm sure theres an answer to the glitches I was getting on 72mg,but I really like how this new radio is working.Albeit only 6 ch on a big twin,I have to put up with single stage flaps,and throttles on only one channel,but I can deal with that.Once the Futaba 8 channel modules come out I'll install it.I still have finish up a few things before I bring it out for some taxi tests later ... As you can see the antennas are protruding the bottom of the fuse.I may change this to the top.There is some debate here whether there is more exposure on the top or bottom.
I also ordered some more cowls from Nick Z.,they'll work well with these engines plus they're scale.
ID:	703223   Click image for larger version
Old 06-14-2007, 03:09 AM
  #499
ivves
Hi.
Just wanted you to know that alu. covered DC-3 is a great flying machine !
Ivan
http://www.junkshop.nu/flyg/micros_i...ve_dc3_big.wmv
www.ivan-hallberg.magix.net
Old 06-14-2007, 06:53 AM
  #500
SteveD-RCU
SteveD-RCU's Avatar
Nice job Ivan,great video.
