Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Ziroli DC-3
Reply
Old 11-01-2004, 04:49 PM
  #176
SteveD-RCU
SteveD-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Ziroli DC-3
Hi Fred; The pilots are from Ziroli and the cockpit is scratchbuilt.I downloaded a panel off the net and started from that,there's a ton of cockpit pictures on the net.There is a kit available out there.Dynamic Balsa has a kit. http://www.dbalsa.com/
..I made mine out of wood and plastic odds and ends.
SteveD-RCU is offline
Old 11-10-2004, 11:36 PM
  #177
SteveD-RCU
SteveD-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Started some sheeting after I installed my seperate tail wheel servo and nyrod setup.Its a mg high torque servo and I mounted it beside the others on the forward tray.Also installed the dorsal fin and the ply wing fillet bottoms,then decided to see how she sits on the centre section.She needed a bit of adjustment but went together just fine.Got to install the centre wing mounting blocks tomorrow,then I'll do some more sheeting.
ID:	192015   Click image for larger version
ID:	192016   Click image for larger version
Old 11-16-2004, 08:49 PM
  #178
jonstotz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you guys for all the pictures.. my wood is coming next week for my dc3. Thanks again Jon
jonstotz is offline
Old 11-17-2004, 05:08 PM
  #179
SteveD-RCU
SteveD-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good luck Jon;And keep us posted with your progress..Steve
Old 11-21-2004, 08:53 PM
  #180
SteveD-RCU
SteveD-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Decided to go ahead with a cargo door,so I cut that out and started the wing fillets.
ID:	195365   Click image for larger version
ID:	195366   Click image for larger version
ID:	195367   Click image for larger version
Old 11-21-2004, 08:58 PM
  #181
SteveD-RCU
SteveD-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used Bondo to fill the front section of the fillet and sheeted the rest.Now to the other side to finish that ,and then back to the cargo door.
ID:	195369   Click image for larger version
ID:	195370   Click image for larger version
ID:	195371   Click image for larger version
Old 11-23-2004, 07:57 PM
  #182
SteveD-RCU
SteveD-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Finally finished the fillet trailing edge section.Lots to sand yet.I also have some more sheeting to do around the tail section ...
ID:	196012   Click image for larger version
Old 11-24-2004, 06:11 AM
  #183
justrfb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice work! I watching for every update with anticipation and amazement...
justrfb is offline
Old 11-26-2004, 04:12 PM
  #184
jonstotz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Steve looking good the little brown truck brought mine yesterday. I'm not sure what to start on???Any sugestions Thants Jon
jonstotz is offline
Old 11-26-2004, 05:36 PM
  #185
SteveD-RCU
SteveD-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I built tail section first,then I went to the outer wing panels,centre section,and then the fuse.
Old 11-28-2004, 11:06 AM
  #186
SteveD-RCU
SteveD-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm still considering the radial engine option.The Saito 170 's valve covers would protrude through the cowl 1/8 " or so,not really too much.I'm also thinking I may redesign the cowls to completely cover the engine valve covers.I know there is a lot of pros and cons on this.What do you all think? There just happens to be a S170 auction in the marketplace forum and I may place a bid .
ID:	197311   Click image for larger version
ID:	197312   Click image for larger version
Old 11-28-2004, 11:36 AM
  #187
William Robison
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Steve:
Go for it. Nobody will ever notice such a slight error in the cowling size.
And think of the sound!
Bill.
William Robison is offline
Old 11-28-2004, 11:59 AM
  #188
SteveD-RCU
SteveD-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ah yes the sound would be awesome,less vibration..sure there's higher fuel costs but who cares.Thanks for your input Bill
Old 11-28-2004, 08:15 PM
  #189
jonstotz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would like to ask a stupid question,why do only three of the stab ribs have tabs???I don't see any reason or way to build like this. Thanks Jon
jonstotz is offline
Old 11-28-2004, 09:06 PM
  #190
SteveD-RCU
SteveD-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I guess Nick figured every other rib didn't need tabs.You could add some blocking if you want.
Old 12-04-2004, 02:46 PM
  #191
jonstotz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Could somebody please post some pictures of the elevator Thanks Jon
jonstotz is offline
Old 12-09-2004, 10:28 AM
  #192
SteveD-RCU
SteveD-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had some shots of the elevator posted earlier but I guess you need some detailed pics?Unfortunatly mine are now covered.Look at my earlier posts and there are some pics there.
I've decided to stick with the US 41's for now because they have more power basically for the shorter field takeoffs(our field is only around 350' with another 50'- 100' being considered to add on.I sure hope we can get that done soon).
I just finished the forward lower fillets at the fuse wing joint.I also finished up the bottem sheeting.Right now I'm just doing a lot of sanding on the bottom side.I also am fitting the cowls and dummy engines etc.
ID:	201043   Click image for larger version
ID:	201044   Click image for larger version
ID:	201045   Click image for larger version
Old 12-18-2004, 07:36 PM
  #193
SteveD-RCU
SteveD-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Finished the horizontal stab fairings using 1/8 sheet top and bottom
ID:	204375   Click image for larger version
ID:	204376   Click image for larger version
ID:	204377   Click image for larger version
Old 12-18-2004, 07:43 PM
  #194
jonstotz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Steve she's looking real nice.I have my tail feathers all done,hope to start center section tomarrow thanks for the posts. Jon
jonstotz is offline
Old 12-18-2004, 07:55 PM
  #195
SteveD-RCU
SteveD-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Finally got at the cargo doors doing the aft door first,I built the door frame conforming it to the fuse and tacked it in position until it was sheeted with 1/8"balsa.Then I removed it and added Robart hinges which I'm using because I have nothing else at the moment.I'll replace these hinges with those butt hinges or something similar when they come in.Tower has them backorderd .
The front door holds the back door closed when its latched.Still some tweaking to do here once I get some better hinges.Till then I'll work on the nose.
ID:	204385   Click image for larger version
ID:	204386   Click image for larger version
ID:	204387   Click image for larger version
Old 12-22-2004, 04:50 PM
  #196
smokebox12000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi
Just to say hello, I am Paul from the Uk
and i shall be starting the DC-3 next month
as we now have a retailer here that does the
Zirolli plans I am looking forward to starting
this beautiful aircraft. Here's to the future
and a Happy Christmas to you all.
smokebox12000 is offline
Old 12-22-2004, 04:59 PM
  #197
SteveD-RCU
SteveD-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Paul;Looking forward to hearing of your progress with your DC-3.Happy Holidays to all you DC-3 fans and everyone else...
Old 01-01-2005, 05:31 PM
  #198
smokebox12000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi
Paul from the UK, Hope you had a great
Christmas and all the best for the new year.
I have read every post about the DC-3 and
I have decided to go with the US41s for the
power plants with a central fuel tank 50oz
I believe, what i wanted to ask by way of a favour would it be possible for you to send me a
list of all the servos you used in your DC-3
EG. HITECH HS700 would be very grateful if
you could do this either through these pages
or via email
Thanks Paul
Old 01-01-2005, 09:17 PM
  #199
SteveD-RCU
SteveD-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi paul; I used 2 1/4 scale Hi-Tec 700's on the elevators,1 645 MG on the rudder (pull pull),2 645 MG's on the ailerons,2 605BB's for the flaps,1 Tower MG Hi- Torque for the tail wheel , and I Fut mini for the retract valve,all on 6 volts.Right now I'm working on the glass install for the cabin and will then glue it to the fuse.
Old 01-02-2005, 06:07 AM
  #200
smokebox12000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Steve
Thanks very much for the info,
I am buying bits while i am waiting for the plans
to arrive, and also there are no kit cutters in
the UK so it will be back to the bandsaw for me.
Wish you well with the nose section and keep up the good work.
Thanks again
Paul
Reply
Display Modes
