Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Caribou build 98 inch
Reply
Old 11-09-2015, 01:41 PM
affas
affas's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
https://www.youtube.com/watch?v=FaNTrauLDyY
affas is offline
Old 11-09-2015, 10:40 PM
91zulu
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sweet, well done.
91zulu is offline
Old 09-23-2016, 01:22 AM
affas
affas's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
https://youtu.be/0gAULPWfLdY
affas is offline
Old 12-01-2016, 07:37 AM
warbirdz54
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gentlemen - l am almost finished building 98" C7 Caribou and would like to know travels for ailerons and elevators - instructions way off . I powered mine with ZenG20s , thanks- Bill
warbirdz54 is offline
Old 12-01-2016, 09:54 AM
warbirdz54
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Alt - enjoy your pictures ! - lm finishing my Caribou powered with Zen G20s and the instructions are way off for travel on Ailerons and Elevators , what are you using? Also is the 110 mm for the CG OK to use? - Thanks , Bill
Old 12-02-2016, 07:38 AM
  #31
warbirdz54
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gentlemen - lm finishing up my Caribou which l powered with Zen G20's sand l would like some info on Aileron and Elevator travel set-up as instructions are way off -Thanks Bill
Old 12-03-2016, 10:48 PM
  #32
alex5
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
travel for the real deal was 55 degrees flaps,but I am sure that a lot less would work(like around 40)...even less.as you want to maintain flow,to generate lift,on a small wing
alex5 is offline
Old 12-03-2016, 10:57 PM
  #33
alex5
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
travel for the real deal was 55 degrees flaps,but I am sure that a lot less would work(like around 40)...even less.as you want to maintain flow,to generate lift,on a small wing Quote"
The control aerodynamics are worth studying,for few of them are readily apparent. Double-slotted, high-lift flaps are lowered to a maximumof 50 deg.They extend out to the wing fences,outboard of which is a fixed leading-edge camber.
alex5 is offline
Old 10-25-2017, 12:55 PM
  #34
US1A kai
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Caribou
Hii all,
Just today i purchased Caribou from CY models.
Also i plannig to add saito FG11~14~17 (Use CW &CCW spec) power.
Which engine the best fit for this model?
Any way, guess FG21 is perfect power weight ratio but caribou cowrlng is not so large for this power plant.
i'm wondering....lol.
Best Regards,
K.Tanabe from Japan
US1A kai is offline
Old 10-25-2017, 02:19 PM
  #35
alex5
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
try to weigh all the parts in the box,then remove the box,weigh the box.The resultant weight is the weight of your plane(my guess around 10 lbs,or 4 kilo) then add the weight of your servos batteries, fuel tanks and engines,to give you a rough idea.(maybe 16 to 17 lbs) Then go for the ideal power .
alex5 is offline
Old 10-25-2017, 04:41 PM
  #36
alex5
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
go electric g62 turnigy.Take a side on foto,of the nacelle,scale it.then add a side on photo of the engine,scaled.You will see if it is dooable.Usually the head is too big.
alex5 is offline
Old 10-25-2017, 05:37 PM
  #37
alex5
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Caribou and saita fg21
I see the projection beyond the cowling will be almost 2 inches for the saito fg21.Cant seem to get it to paste the cad version that I had.
alex5 is offline
Old 10-25-2017, 06:59 PM
  #38
alex5
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
here is the snap I took.
Name:	Saito fg21 specs inserted in cowling.JPG
alex5 is offline
Old 04-17-2018, 03:25 AM
  #39
US1A kai
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
one more pic.
Hi all,
Cy caribou repainting to MPS 002 Costa Rica securty police scheme.
US1A kai is offline
Old 08-24-2018, 02:51 AM
  #40
US1A kai
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
HII all,
Fainally my Caribou has finished final assenbly on mid of Aug.
But its dry weight was almost reached 10.8kg !!
I wanna to know about other modeller's CY caribou.[QUOT[/QUOTE]
US1A kai is offline
Old 07-09-2019, 05:59 AM
  #41
Austars
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Dave from Australia and all the customers from worldwide, thanks for sharing the experience. We just set up the global service centre over FB. Let us know if you need support or parts.
Cheers
Teamaustars
Austars is offline
