Go Back  RCU Forums > RC Airplanes > Twin & Multi Engine RC Aircraft
Reload this Page >
I need a little help programming my JR 9503 please
Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Old 01-25-2014, 01:56 PM
Lil Hoss
My Feedback: (58)
Lil Hoss's Avatar
Default I need a little help programming my JR 9503 please
A while back I had a Top Flight B 25
Some one on this forum helped my program my radio to tune each motor AND shut them both off using the trim next to the throttle.
My radio is the JR 9503 heli version and I went through the manual a couple times trying to remember how to set both motors. I can't find it any where in the manual.
Can someone please refresh my memory and tell me where to plug each motor into the Receiver? I no one goes into the throttle channel but where does the other motor plug into?? Is there a mix involved too?? I should be able to tune each motor individually.
Thanks guys
Hoss
Old 01-26-2014, 08:47 PM
Mpizpilot
My Feedback: (45)
Thanks guys
Hoss
i dont one have mine in front of me, but you have to get into the setup menu by holding down the top left button when turning it on. It takes you to the wing type menu. Twin engine setup is in there.
Old 01-27-2014, 07:40 AM
Lil Hoss
My Feedback: (58)
Lil Hoss's Avatar
Thank you Mpizpilot.......
Yes I went into that program and found it.
I click on it but it won't activate. It stays inhibitied.
Can you please help me a bit more???
One other thing, 1 motor goes to Throttle, where does the other motor plug too and will there be a mix??
THANK YOU AGAIN........
Hoss
Old 01-27-2014, 09:34 AM
MarvinLoomis
My Feedback: (20)
Use Aux3 as the other motor throttle. You have to make some changes in the setup also.
Old 01-27-2014, 09:37 AM
MarvinLoomis
My Feedback: (20)
When you are in the twin motor setup you need to highlight the INH then push down on the scroll knob on the right side of the display to change to ACT. I don't have mine in front of me, but just went thru this on my B25 this weekend.
Old 01-27-2014, 11:13 AM
Lil Hoss
My Feedback: (58)
Lil Hoss's Avatar
Thanks guys...........
I Think I might remember how to do it....
Will I be able to sub trim aux 3 for minor adjustments??
Thanks again
Hoss
Old 01-28-2014, 05:39 AM
MarvinLoomis
My Feedback: (20)
Yes you can trim AUX3 by using the hov pitch or the hov throttle buttons in the center of the transmitter, but you need to ACT it in the wing type mode under the TWIN E settings.
Old 01-28-2014, 05:49 AM
Lil Hoss
My Feedback: (58)
Lil Hoss's Avatar
Yes I found that out.........
I also went into Aux 3 subtrim and did some fine tuning.
I think when and if the weather breaks here I can take it out and try them. Man it's cold here.
Thank you much for helping me. I think I can handle it from here.
Oh yeah,,,, The motors are in a new Seagull twin Comanche. What a NICE model
Thanks again
Hoss
