Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Henschel 129 80"
Reply
Old 09-12-2004, 04:55 PM
clifford
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Henschel 129 80"
Hi chaps...thought you"d like to see my 80" He129...plan was blown up from a smaller 55" hand-launced job......I"m currently writing the review for RC Scale International, the plan will be published very shortly, the plane flies beautifly o two OS 54 Surpasses...1/2 throttle gives scale speed.....and really different in the air.....a.u.w=14-15 ibs.......washout built into the foam wings....lands like a baby......and takes standard 90% retracts........
Clifford
ID:	172636   Click image for larger version
clifford is offline
Old 09-17-2004, 12:21 PM
stefanP
stefanP's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Henschel 129 80"
Clifford will there be any vacum formed parts? or glass parts like cowels? It looks very nice in the air. Have a good day! stefanP
stefanP is offline
Old 09-17-2004, 03:57 PM
rrudytoo
rrudytoo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Clifford,
That is one nice plane! Like StefenP, I want to know more about this design, as well. Which retracts were used? ABS or 'glass parts and canopy available? I want one of these!!!
Al
rrudytoo is offline
Old 09-19-2004, 02:58 AM
clifford
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Stephan and Al...thanks.
....the cowls are abs....on the prototype I got some "blanks"....sports type, that can be bought readily...also purchased some extra 12" sheets of more abs to extend them to the correct length......inside is then coated with light cloth and soaked with thin cyno.....this strengthens them greatly..
....the canopy is very easily made from scratch...no curves...everthing is straight....I"ll get a couple more pics up....and have a full set of building pics if anyone wants them....fell free to e-mail me if you need help......the plan will be available from Traplet Publications shortly...
plane has now got 35 flights on it.......one dead-stick....chopped the live engine and glided in.......seen it soon enough, and not a problem....it really is a good flyer....and a mean looking tank killer as well........nice size too......not tooo big for transport....and still has that "presence" in the air...deffinately different......and very cheap to make....wait to you see the fuse parts count.......
Cliff
clifford is offline
Old 09-19-2004, 03:14 AM
clifford
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
here you go....more pics....If you"d like me to continue the thread from the very start, ie...the complete build.....just say, then you can ask all the questions you need!....how about it?
ID:	174791   Click image for larger version
clifford is offline
Old 09-19-2004, 03:28 AM
rrudytoo
rrudytoo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
clifford,
If you're up to a complete build report, I'd love to see it! Do us a favor, though. When the plans are published, post a link to the magazine on this site so those of us in the states may have access to them for order. I'm not able to get that mag where I live.
Thanks for the pictures. You've done a very good job!
Al
rrudytoo is offline
Old 09-19-2004, 05:24 AM
clifford
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK..I"ll make a stsrt!!......here"s the main details of the project..
Henschel 129 single seat Tank Buster/Ground attack WWII
Span...86"
Target Weight....14-15lbs
Power...two 52/60 f/strokes
Fuse...built up....wing...foam core....tail surfaces...built up
Wing area...1"044 sq ins
Wing loading....43oz per sq ft.
The main thing to remember with this...and any...project is to keep things light......the fuse will have barely any weight at all......no need to go beefing things up either......as you will see...the way that the wing braces are done....will ensure that all laods, ie...engine...and retracts....will all be interlocked so that the landing loads....engine bearers etc....will be spread around.........right then...first pic....
1/8 sides.....1/2" triangular stock....some 3/16 doubler [wing seat]......and lightened 1/16 ply......very little parts needed to get you going.....I"ve arrowed in the lightning holes on the ply......every bit counts.....
ID:	174797   Click image for larger version
clifford is offline
Old 09-19-2004, 07:56 AM
stefanP
stefanP's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Clifford your to kind.One thing that is nice about this plane is that the fuse is not round with many compound curves.Also it is a subject that isn't modeled that often.Please advise when the plan will be published. thanxs ,stefanP
stefanP is offline
Old 09-19-2004, 10:08 AM
clifford
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Stephan..
...no problem posting the pics and telling the story of the build....that"s what forums are for!....I"ll keep posting away, every night or so...then you can save them for when the plan comes out....don"t worry about getting the plan...or a copy of the review....I"ll sort that out for you at this end!!.....only have the introduction writtten out so far......but the masterplan is with the editor at Traplet.....he"s just waiting on me getting the typing done..
As you said the fuse...yep very easy.....just keep it straight...I found it easier to keep the forward ply former to the last....tightish bend here so so the rear first...
After the front end is pulled in, then scrap balsa block is added to allow for the cannon troughs.....remember to add some to the inside as well...this will allow you to have extra material to carve out, and not end up with holes/slits in the troughs.....lot of carving and sanding, but this area is where the 129 gets all it"s character from......
Cliff
clifford is offline
Old 09-19-2004, 10:16 AM
clifford
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Couple more pics....the tail surfaces are simple built up ....1/16 sheet core...for fin/rudder/elevators....the guy that cut my wings for me did me a set of stabilizers....you can build them up as well...details on the plan....
ID:	174866   Click image for larger version
clifford is offline
Old 09-19-2004, 01:35 PM
Ram-bro
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
man, that airplane is so ugly its beautiful........got me wanting one
Ram-bro is offline
Old 09-19-2004, 05:06 PM
clifford
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello Ram-bro...
..yep...she"s a mean son-of-a-b***h !!!.....a kind of "warped" beauty....but it"s in the same league as it"s single engined brother the Stuka......an extremly effective killing machine......in the air it"s really nice !!!!....on the ground you think it"s going to bite you!!
Another plus is that the cowls are standard "sports" type blanks.....with balsa detailing added...[under nacelles etc]......the white arrow shows the bit added on for proper length.....spinners.....Brian Taylor FW 190 does the job.........and 4" FW190 wheels suit her as well.......
ID:	174980   Click image for larger version
clifford is offline
Old 09-19-2004, 05:08 PM
rrudytoo
rrudytoo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
clifford,
You're killing me, man! I feel like I'm being pulled to the top of the first hill on a roller coaster awaiting imminent release. I don't even know how this thing's gonna go together and, yet, I want one!
WHEEEeeeeeeeeeeeeeee!
Al
rrudytoo is offline
Old 09-19-2004, 05:22 PM
clifford
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
...ok then...another pic to keep up youe appetite!......be back tommorrow night....
clifford is offline
Old 09-19-2004, 07:42 PM
stefanP
stefanP's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cliff get that TYPING done!! I WANT THE PLAN I like the tank buster version,stefanP
stefanP is offline
Old 09-20-2004, 02:42 PM
clifford
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
...right then...more pics...here"s the carbon elevator push-rod, no slop is a must....with the long fuse and leverage to consider, then the wing panels....foam core, and, most importantly...4% of washout cut into them.....next is the nacelle parts....and the 3/8thsq bearers....these will interlock with the forward main spar, and carry the undercarriage load....note the lightning holes even in these......keep her light...
ID:	175312   Click image for larger version
ID:	175313   Click image for larger version
clifford is offline
Old 09-20-2004, 02:59 PM
clifford
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
two more pics.....first shows how to leave the engine line part of spar unlightened..[white arrow].......next pic shows the nacelle sides epoxied in position....care needed here to maintain equal downthrust between the two wings......red area is discarded/cut out....green area shows where 3/8 Triangle is used to tie in the nacelles with the wing spar......is it ok for you?.....
ID:	175319   Click image for larger version
clifford is offline
Old 09-21-2004, 04:21 PM
rrudytoo
rrudytoo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
clifford,
Are you going to make the styrofoam wing cores available or just the templates from which to make them? Whose retract gear did you use?
I am LOVING this link!
Al
rrudytoo is offline
Old 09-22-2004, 10:10 AM
clifford
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hello Al....there"s not a set of wings going to made available, but there is lots of people out there to do the job......just take/send, the root / tip templetes, and tell them to add 4% washout......problem solved,.....retracts....I used standard 90% century units.......suppose the cheaper ones will do as well.....use the heavy duty units....and sprung oleos.......helps a lot...the plan shows the correct angle to set them at....ie...wheels retracted=slight off-set......wheels down=straight ahead...same as full size....here"s acouple more pics....I used a little piece of hard rubber between the firewall and mount, to help dampen the virbration a little....also shows the 10 oz tanks......mounted on their side..make sure and adjust the pluming to suit!......
ID:	175853   Click image for larger version
ID:	175854   Click image for larger version
clifford is offline
Old 09-23-2004, 06:21 PM
stefanP
stefanP's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cliff pictures looking nice.Thanxs for keeping us updated.Like I said earlier please let us know when the plan can be purchased.stefanP
stefanP is offline
Old 09-26-2004, 04:29 AM
clifford
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More pics for you...here is the underside nacelles...and the scrap piece of abs used for the sub cowling...comes off seperately to be practical, and gives access to the throttle servos....
ID:	176927   Click image for larger version
clifford is offline
Old 11-02-2004, 06:26 AM
Jimmy Bananas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just read a posting that Radio Control Scale Int., magazine will not be published anymore...Is this true?? Anybody else heard about this??
Jimmy Bananas is offline
Old 11-03-2004, 04:41 AM
rrudytoo
rrudytoo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
.................and Clifford along this link disappeared toward the end of September. Hmmm.
Al
rrudytoo is offline
Old 11-03-2004, 04:32 PM
clifford
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yep...been very quiet !!!...working some overtime etc etc...it"s true...RCSI is no more...BUT...the plan is finished and will be published in Radio Control Model World, also a Traplet Publication......I guess there"s just fewer and fewer outlets for a "specialist" magazine now......any of you chaps still interested in the 129?....the plan is finished...and will be available very shortly.....
Cliff
clifford is offline
Old 11-24-2004, 04:43 PM
stefanP
stefanP's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cliff I want a copy.Please let me/us know what magazine &when it will go to publish.I thought you might talk about it over a rcscale builder but all I see is your thread on the Albatross stefanP
stefanP is offline
Reply
Display Modes
