Z B-25 Power
Z B-25 Power
I have a Ziroli B-25 which came out at 34 lbs. I also own 2 RCV 1.20s and would like some input on weather this would be adequate power for this model.
Thanks Dean
Thanks Dean
RE: Z B-25 Power
Dean,
My Z B-25 weighs 31 lbs, and flys fine on a pair of webra 120's swinging Graupner 16x8 three bladed props. No lack of power at all, as long as you fly it as a B-25 was designed to fly. It dose lack a bit in vertical manouvers, however...... (VBG)
My Feedback: (7)
RE: Z B-25 Power
Dean My z-25 weighs 34 lbs also and I fly it with two G38 whitch is about the same as a 120 four stroke . and it flys it fine. I even throtal back once it is in the air.
My Feedback: (90)
RE: Z B-25 Power
ORIGINAL: Baldeagle
There are several on RC Warbirds with a wide range of power: http://rcwarbirds.com/bombers.htm
AB, CANADA
RE: Z B-25 Power
I fly my Ziroli B25 with two OS 90's weight is only 30 lb I found living in altitude of 3000 ft I have plenty of power. Keep in mind that G38 and any other gas engine will weigh more and it will stick out of cowling.
