Seagull's "Dual Ace"
#103
UT
RE: Seagull's "Dual Ace"
Dasintex, I'm flying with OS .52 Four strokers, 11 ounce H-9 fuel tanks. Work's "peachy". Also added a rear strut to the mains. That stiffened them up. Plus dual nose wheels too. Tinted the inside of the windows, looks better. Three blade prop and spinners work fine for scale flying. nto the next. MM
#104
I've been flying trainers for about 2 years. I can do basic aerobatics. I'm ready to go to something else. I love the looks of this plane. I considered the Twinstar as my next plane but too many experienced pilots said the twinstar was too big of a leap from trainers. I was told the Twinstar could be difficult to land. Is this plane easier to fly and land than the Twinstar?? I'd love to fly a twin but I haven't lost my mind yet.
#105
ORIGINAL: Alvin
What servos are you using?
AL.
AL.
ORIGINAL: Jimmy Bananas
Tried to install the retracts I had...It's a no-go...too heavy with 3/16" wire..if you try it,use 5/32" wire....going to make new LG wire out of 5/32", with one loop in the wire....Now I'll go back and repair the damage I done on the right wing.....had to do alot of cutting of the wood (Ribs)....will balance the wing when it's done....should still be a great flying plane.......also will try to post pictures..you mention "Embed picture in post"..will try it and see what happens.......
Right now I have to finish my P51 D. One wing left to cover and then put everything together, this will take this week. Maybe I can start on this the coming weekend.
If you have pictures – let’s see! thanks
Happy landings[sm=thumbup.gif]
G-Pete
#106
ORIGINAL: caboose
My buddy build a Twin Star right now – if you can wait I could give you some insight look of this airplane. He flies a Nextstar for a year and a Seagull PC 9 - he put OS .40 in this plane...
The Twin Star is a way smaller airframe and weight pretty much the half. I have to mention she flies at the simulator pretty good.
Most comments about the Twin Star are positive and if you not fail and panic – you can fly here around with one engine and safe land. In the first minute you will not even notice you lost an engine – your speed just drops.
Here is a [link=http://www.rcgroups.com/links/index.php?id=4790]LINK[/link] about the twin star
Good luck to you Caboose, I hope your plane do not make caboom!
G-Pete
#107
My Feedback: (13)
IA
G-Pete:
Yes,am not going to install retracts...The part of the Rhom -air retracts that fits down into the wing. is too long...Maybe the ones you're getting the body is smaller.....Just be careful when you start cutting the wood..have mine all repaired now...Just have to put on the bottom sheeting....Don't know how to put pics on here (The ones I took with my digital camera)...just give me your e-mail address and I'll send you some..Just watched your video that showed your engines running...Man,what a sound...I think they are broken in :-))...........
#108
Jimmy,
Just too sad you had to cancel your project. I sent you an PM with my e-mail address. Yesterday I tried slower landings --- that’s a no no. She will drop a wing very fast, if you don’t keep the speed up. The low rates on the elevator are too low for the landing approaches. If you try to flair the plane the elevator input is to small for touchdowns on the main gear. The angle of attack would be also bigger, so the plane slows nicely down. Today I try the high rates on the elevators…
G-Pete
G-Pete
#109
CA
Got mine today,....everythings good,..no damage....looks great..
Glad I've got you guys experience to follow in the assembling process.
G-Pete..took your advice..picked up a couple Sullivan 10 .oz flex fuel tanks...test fitted them already...perfect fit...
Can't wait to get started on this and get this plane in the air.
George
George
#110
I just finished my Seagull Dual Ace with 2 Evo .46's and it's on charge for a test flight tomorrow.
I did add 10 ounces to the nose for balance. I'm going to test it that way, then start pulling some out to see what happens.
In my opinion, the instructions leave a lot to be desired. Some steps are pictures with no words. Some areas are totally left out like gluing on the ply washers on the holes for the wing bolts.
Pretty nice hardware as ARF's go. The spinners don't look like they will last.
There is a long, unsupported run for the rudder pushrod. If you have to hold right rudder, you might not get much against air loading. If the plane flies well, I think I'll look into changing to pull-pull with cables. They'll be lighter in the rear and much more positive.
#112
My Feedback: (24)
This support info has been on Horizon's site for a while now:
Dual Ace 46 Twin ARF Team Tips
Mounting the Nacelle
I found it easiest to mount the nacelle by first cutting the engine openings as stated in the manual, then I installed the bottom half of the nacelle with 2 screws on the wing, one screw in one of the front screw locations on the wing and one screw in the back of the nacelle on the wing, making sure that the front of the nacelle lines up with the spinner. I then installed the plywood strap/nose ring, which holds the 2 halves together in the front of the nacelle as shown in the pictures. Then I installed the remainder of the screws in the top and bottom half of the nacelles on the wing keeping the front of the nacelle lined up with the spinner, followed by a couple screws on each side going into the ply of the motor box holding the 2 nacelle halves together. Be sure if you drill holes for the screws on the side that you do not puncture or damage your fuel tank.
Balancing
The proper CG range is 80-95 cm from the leading edge of the wing at the fuselage. This is roughly 3 1/8" to 3 3/4". To achieve this CG, this model required roughly 10 ounces of weight in the front of the cowl, with the battery placed as far forward as it will go inside the fuselage. Be sure that your CG is within the CG range for proper flight performance.
Balancing
#114
I got one test flight in today because it was windy, 15-18 kts and gloomy, cloudy, threatening rain.
Since I was doing a kit review, I played novice with the 2 Evo .46's and installed them out of the box, no break-in, no tuning in the driveway, just crank, give a quick tune and fly. Each cranked with 1 back flip-I have witnesses. One flip each. I leaned them out. I didn't touch the low end. I taxied out, took off and flew. Take off was smooth without any woopsies. I have this tendency to put in 3D controls so my test take offs, at times, can be exciting. Excellent flight. My ailerons were a little sensitive. I put in all the throw I could get and got interrupted and forgot to set any expo so I wiggled the wings at times. Landing was nice. I taxied back in with both Evos still turning. This was my first use of the Evo .46 in a twin and right now I am impressed.
My plane came out at 11 lbs 15.6 ounces, say 12 pounds.
Tomorrow, I want to try some acro and then during the week, I'll take some lead out. I think I'll also ditch the Master Airscrew 11-6 props for some APC 11-5's and kick the speed up a little.
The red spinners have to go. I also think I'll paint the nacelles blue to match the wing. Ultracote doesn't have paint to match the turquoise.
I like the plane. Barring any unexpected mishaps, I'll have it at Multis Over McDonough and hope to see some of you there.
#117
My Feedback: (29)
MO
I agree with you, Ed, the red spinners are an insult to this beautiful model. They really stick out in the air. Mine made it's debut today on a mild wind and blue sky day, flew great much to the delight of an anticipating crowd. I also agree with the APC props. I'm running twin OS .46 AX engines (with Top Flight wood 11x6 props today). The OS's tached at 10,500 (using 10% fuel) on the first flight (I had run them on the ground twice for about 5 min each time). Second flight, we cracked the RPM up to about 11,500. Roll rate on recommended high rate is impressive. Low fly bys are astounding except, as we said, for the red spinners. I'm running the stock tanks but plan to go to the 10 oz flex tanks for more run time. I use flaperons and I think it needs a little more flap to slow it down. I have rates on rudder and it needs high rate for landing ground steering. Our runway is only 30 feet wide. I had trouble turning it around on low rudder rate. I put a couple of trim stripes on the nacelles to break up the bland look. They really need dressing up a bit. This bird really needs retracts. I'm sure I will retrofit some in soon.
#118
UT
Well, add me to the list of happy fliers. Maidened mine just "peachy". Three bladers just fly it at 4500 feet altitude so we'll go back to APC's standards. VERY NICE INDEED ! . Seeya, MM
#119
ORIGINAL: Kmot
Hey Ed, I am pretty sure I read somewhere (RC Report maybe?) that the Evolution engines are actually broken-in at the factory before they are boxed. Probably explains why they run out of the box.
This is the major experience here with the Evo’s .45, .46 and .61. Other then that, they run fine.
G-Pete
#120
My Feedback: (7)
NC
How big of a prop will fit this model? Reason I ask, is I am thinking of converting to e-power, and the motors I would use, since I have two on hand, normally use a 15" prop. I can go 3 blade and maybe reduce that to a 13" or 14". Extending LG is easy, but nacelle spacing is another matter altogether. Those using 12" props, how close to fuse are you?
thanks,
David
thanks,
David
#121
David,
There is plenty space between the engine and fuselage and I think a 14 inch would fit. I will measure tonight the distance between the shaft and the fuselage.
I have 12 inch props, and I had to get 3inch wheels to clear the props for our rough field.
E-Power, the only problem which I see is the amount of weight you have to add in the nose. You could pack the nose full of batteries and stay up for an hour or so…just kidding.
But serious, what do you think doing about the weight issue?
G-Pete
G-Pete
#122
I need some ideas. I am using two O.S. 46's on the Ace and I am having a tough time working out the linkage from the throttle servo to the throttle. Perhaps I am going brain dead in my old age but I just can't seem to get a workable linkage going. How about sharing some ideas with me on how some of you did the trick.
TIA
John
TIA
John
#123
Here is what I did, my engines are a little bit bigger (OS .60) but the linkage and throttle position in relation to the nacelles are the same.
Hope this helps…
G-Pete
Hope this helps…
G-Pete
#124
NE
Jfail1,
I am also using OS 46's in my Dual Ace. I switched my stock throttle linkages out and added two dubro cable linkages that I resurrected from my rc boating days and they give enough bendability, if that is a word, and worked perfectly in mine. They are available from your LHD. I was having trouble with the way that the stock linkage and the way it had to bend to get to the control surface of the servo too. Sorry there is no pictures.
Hope this helps!
Hope this helps!
