Pilot Twin Ace kit
Pilot Twin Ace kit
I recently bought a old Pilot Twin Ace kit and intend to start on it soon.
Just wondering if anyone has experience building and/or flying this kit?
I plan to put two 30-size 4 stroke, or two 20-size 2 stroke.
Chris
Chris
Re: Pilot Twin Ace kit
Chris
Chris
The kit is very easy to build with all parts accurately cut and fitting together well. It is very easy to assemble components "dry" to check for fit before glueing in place. One trap is in the sidethrust shown on the plan. The plan shows the port nacelle only and this has right thrust built in. It would be very easy for the unwary to mirror this for the starboard nacelle and build inthrust into both nacelles. I actually built out thrust into both sides, left thrust on the port nacelle and right thrust on the starboard side, which resulted in excellent single engine handling.
I plan to use two of the OS 30 4-strokes this time round as, from memory, power is about the same as the old 25 FP.
I also would be interested in hearing any reports of small 4-strokes in the Pilot Twin Ace.
Col
Pilot Twin Ace kit
Thanks for the tip the engine mounting. I haven't reach that stage yet, but the building is progressing smoothly so far.
I am quite tempted to use Leo 37s, but it could be on the heavy side.
Pilot Twin Ace kit
Where are you up to in construction? I have mostly finished the fuselage and tail feathers and am about to start on the wings. They next hurdle for me is saving for the two OS 4 strokes.
Col
Pilot Twin Ace kit
Yes I am quite tempted to put in the Leo 37. Only issue is the extra weight. Since I already have a Leo 37, it seems a more attractive choice.
I've got the wings framework done. Then I stopped for a while, trying to figure out how to put retracts in.
Chris
Chris
Pilot Twin Ace kit
Originally posted by Boongala
I would like to ask Seahawk if he bought his Twin Ace kit in Australia, as I am thinking of buying one.
Regards
Garry
Regards
Garry
No, I found mine in Singapore. I am not sure if I can name the source in these forums so email me at [email protected] and I'll give you full details. The service from this shop was fantastic, 4 working days from order to delivery.
Col
Chris
Chris
I was wondering if you finished your Twin Ace? Mine is flying, though the engines are not tuned properly yet, and is a bit of a handful.
Col
Pilot Twin Ace kit
Col,
No... it hasn't been moving for a while, cos I was figuring out how to install retracts.
I completed two other kits in the meantime - a Pilot Zlin Acrobat and Extra 10.
Would love to you a picture of your Twin Ace.
Cheers,
Chris
Cheers,
Chris
Pilot Twin Ace kit
Col,
Cheers,
Chris
Col,
Cheers,
Chris
http://www.larcs.com/Colspage.htm
Or go to the club site at www.larcs.com and navigate to Roster then SeaHawk for piccies and then to Special Projects for construction pics.
Col
Pilot Twin Ace kit
Col,
I wonder if you have managed to put in the OS 30 4s on your Twin Ace?
I would be interested to know if they are any weight or cg issues?
Chris
Chris
Pilot Twin Ace kit
Col,
Chris
Col,
Chris
Yes, I fitted the OS 30 4-strokes to my twin ace and it has quite a few hours of flying time up on it now. The weight and CoG are within limits and the 30's are more than powerful enough for the model.
Build in plenty of down and out thrust as the torque from the 4 strokes can catch the unwary if an engine sags or quits.
Col
Pilot Twin Ace kit
Col,
I guess the sound of two OS 4s would be awesome!
I am planning on Leo 37. The weight (270gm) is about the same as the OS30 4s without the muffler. By my calculation, this would bring the all up weight to about 2.7kg, and wing loading about 25 oz/sq ft.
Is this about the weight of your Twin Ace?
Chris
Chris
Pilot Twin Ace kit
Col,
Chris
Col,
Chris
Sounds great and is great fun. (plus you can give sh*t to the other pilots who have never experienced a twin)
Col
Pilot Twin Ace kit
Col:
Looking at the numbers Pauser posted, I'll guess the Twin Ace is about 50" span. Yes?
Looks very similar to the Duellist series planes. Move the canopy back, and the nacelles out a bit, a little change to the V/fin and rudder shape...
Yep. Could be a 25 size Duellist. And they ALL fly like "Poosy Cats."
Bill.
Bill.
Pilot Twin Ace kit
Originally posted by William Robison
Col:
Bill.
Col:
Bill.
The span is 60" projected weight 5.5 lbs for 19-25 2 strokes.
http://www.larcs.com for mine. Click 0n Special Projects then Twin Ace for a small pictorial construction article.
I have just finished a CMPro (China Model Productions) P40 with RCV 58CD engine that I am currently in love with, piccies also available at that site.
Thanks for the reply Bill.
Col
Pilot Twin Ace kit
Hi Col,
I have just seen your Twin Ace construction pictures.
It looks like you build the wing tips from solid blocks. The original plan shows built-up open framed tips. I am also planning to change them to balsa blocks and maybe also increase the span a bit.
Did you also build wash-put on the tips?
Chris
p/s: your black scheme looks real cool - any problems with orientation in the air?
Chris
Pilot Twin Ace kit
Hi Col,
Hi Col,
Chris
I would use a colour other than yellow for the underside also. I am thinking of all over black with white sunburst type design.
Col
Pilot Twin Ace kit
Hello Col,
Do you have weight or cg issues with the two OS 4s on your Twin Ace?
I am quite set to put a couple of Leo 37 on mine. But with the tricycle retracts and the weight of the Leo, I am not sure if it will trip the scale. Leo 37 is about 270 gms each without the muffler.
It's coming along, but real slow. Got the fuse and nose gear done and the wing ribs set.
Cheers,
Chris
Cheers,
Chris
Pilot Twin Ace kit
Hello Col,
Cheers,
Chris
Hello Col,
Cheers,
Chris
I had no CG problems with the 4 strokes. The CG was easily adjusted by moving the radio gear around although I had fully sheeted the tailplane which may have helped a little.
Weight was a little over the recommendations at just under 6 lbs but there was plenty of power available and the model glided well engine off.
Col
Pilot Twin Ace kit
Hello Col,
Thanks for the reply.
Mine would be over the spec's weight with the extra retract servo and the gear.
BTW, do you use one servo or two mini sevos to control the engines? Any problems syncing the revs?
Chris
Chris
Pilot Twin Ace kit
Hello Col,
Chris
Hello Col,
Chris
Yes, quite difficult to get similar movement at the throttle arms. Matching revs was even harder due to the differences in revs from the 4 strokes. My last one with the two strokes seemed easier to match.
Col
Pilot Twin Ace kit
Hello Col
I am thinking of using two mini servos, one slaved to the other. This may give more precise rev matching.
Question is where to put the servos as the rear engine crowling is solid wood block. Maybe inside inside the wing trailing edge.
Chris
Chris
KS
RE: Pilot Twin Ace kit
I have acquired a beautiful Pilot Twin Ace at a club auction (finished but never flown-radio gear or engines never installed), but have found a problem. There is 2.5 degrees difference between the outer left wing and the outer right wing. The left wing has more washout. I've tried hanging opposite weights on yardsticks lashed to the tips and then reheating and shrinking the covering. Got about .5 degrees change. Any ideas about how to correct? Of course, I would like to get more washout into the right wing without having to strip and recover. I have been able to correct this type problems in the past on uncovered wings by dampening and drying while holding the shape desired.
Hawk:
If the wing is film covered, you can hold an excess correction in the panel and reshrink the covering. In other words, if you need two degrees change, hold four degrees while doing the reshrink.
Works for me.
Bill.
Works for me.
Bill.
