Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
NEW KMP TWIN - Adam Aircraft A500
Reply
Old 09-14-2011, 12:03 AM
  #226
superpuma332L1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: NEW KMP TWIN - Adam Aircraft A500
hereĀ“re the next photos of the rear cowling....building Mold Part 2
ID:	1662159   Click image for larger version
ID:	1662160   Click image for larger version
superpuma332L1 is offline
Old 09-15-2011, 12:23 AM
  #227
superpuma332L1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
preparation for Part 3 of the rear cowling mold
ID:	1662513   Click image for larger version
Old 09-19-2011, 11:55 PM
  #228
superpuma332L1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the front cowling mold finished and ready for Production
Part 4 of 6 of the rear cowling...the end is coming
and the main fuselage in the separation bed
ID:	1664505   Click image for larger version
ID:	1664506   Click image for larger version
ID:	1664507   Click image for larger version
Old 09-23-2011, 12:52 AM
  #229
superpuma332L1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Part 4 of 6 of the rear cowling mold
Old 09-23-2011, 01:24 AM
  #230
slevin1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
looking great
Saul
slevin1 is offline
Old 09-23-2011, 04:49 AM
  #231
superpuma332L1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The first protype front cowling was 145 g(only laminated in glasfiber...i think the next could be on the 110 g......
the process of laminating was quite okay...next time i will use vacuum-technic.....
Old 09-25-2011, 11:26 PM
  #232
superpuma332L1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Today ( my birthday) i open the mold for the rear cowling.....
I thought , that it could be difficult, even i had made 6 parts......
but ....
it worked fine and only a little color and mastic from the original model is left in the mold...
now i have to clean the mold and polish and good waxing and start laminating the first prototypes.....
next mold is the main fuselage with only 4 parts (2 for the fuselagemold and 2 ( front and rear firewall) for the rest..
also some photos of the rear cowling
ID:	1666216   Click image for larger version
ID:	1666217   Click image for larger version
Old 09-27-2011, 01:00 AM
  #233
slevin1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking very good!! :-)
slevin1 is offline
Old 10-06-2011, 10:35 PM
  #234
superpuma332L1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Second Prototype of the Front Cowling...the cheap Version for Testing.....but to heavy with 225 g.....just a tool for the mold...after that it will be sold for scrapping
ID:	1670797   Click image for larger version
ID:	1670798   Click image for larger version
Old 10-16-2011, 07:56 AM
  #235
superpuma332L1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
1 layer of glas 49g/qm
1 layer of aramid/kevlar 170 g/qm
total weight of the upper part : 77 g...
next time with gelcoat and vacuum technic
ID:	1675092   Click image for larger version
Old 10-17-2011, 07:03 AM
  #236
Radical Departure
Radical Departure's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow.. looks good!
Radical Departure is offline
Old 12-14-2011, 09:01 PM
  #237
maxiemac
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi all A500 lovers- I finally got back in the saddle and have been doing repairs to my A500 afterhitting the ground hard at landing speed backin Feb 2010 as described in an earlier post.
Progress over the past month has been to finish the wing inside repairs with new ribs and some extra formers where needed, finish fibreglassing damaged wing areas from the inside, strengthening the originalwing skin in areas on the other side of a wing ribwhere awing skin fracture was made to repair it from the inside which meant making more inspection/work holes plus,regluing the LH boom back to the wing centre section where they had separated (it had split thru the wood not the glue).In places Ifitted triangle stock shaped to fit the wing forwing skin section replacements - eg: where a hole had been cut beside arib.
I also made a new RH landing gear plywood structure to replace the original one that broke 'cos it's made of soft plywood. My other retract mount fabricated earlier didn't break 'cos it's made of 'proper' wood. I found it interesting that the wing skin appears to be made of 1/32" thin balsa, or some sort of very thin sheet wood (I don't think it 1/64" 3 ply) that is fibreglassed both sides to make it a strong but flexible skin. I think the wing leading edge was made around a former or mandrel as there is very littlewoodin theleading edge except for formers where wing attachments are, plus some ribs that run up to the leading edge, and in each tail boom leading edge.
Which brings me to:- if carrying your model by a wing leading edge and say the fuselage, take care not to squeeze the leading edge too much 'cos it might fracture laterally - mine did and I had to repair it.
And finally - after sanding back, I laidfibreglassmat onboth the wingtop and bottombetween each tail boom to hopefully give added strength in tension and compression for the undersideandtop side. I laid the f/g mat with polyester resin, sanded it back and then overlaid an epoxy finishing resin laced with microballons. So far I can't bend or twist the wing centre section so I am fairly confident the repairs are ok - time will tell.
The pics show :- wing repairs with original wing skin andreplacement bits of 1.2mm thick 3 ply wood in places as needed, bogged up sections as neededusing red/browncolor auto nitrocellulose blade putty - pretty thin just to even out the repairs, extra inspection/work hatches cut out for access and 1/64" 3 ply shelves cyanoed and/or epoxied in place to accept back the panel that was removed, new retract support prior to instal and a 'first cut' sand of the wing top. Next, more sanding then masking and paint - watch this space
cheers and merry xmas to all (those that have christmas) - maxiemac
smile, it don't hurt
ID:	1700148   Click image for larger version
ID:	1700149   Click image for larger version
ID:	1700150   Click image for larger version
ID:	1700151   Click image for larger version
ID:	1700152   Click image for larger version
ID:	1700153   Click image for larger version
ID:	1700154   Click image for larger version
maxiemac is offline
Old 12-15-2011, 07:39 AM
  #238
Radical Departure
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yikes! Never a shortage of things to do..
Merry Christmas maxiemac!
Old 12-16-2011, 05:29 AM
  #239
slevin1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The repair look great.
Saul
slevin1 is offline
Old 03-10-2012, 11:00 PM
  #240
dmscpu
dmscpu's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Okay I know I am a little late BUT:
Does anyone have an A500 they want to sell?
I would like a New one with retracts if possible.
dmscpu is offline
Old 03-11-2012, 04:32 AM
  #241
slevin1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Best way to get one is to post a wanted ad on RCU. It worked well for me for other planes.
Saul
slevin1 is offline
Old 03-11-2012, 11:05 AM
  #242
dmscpu
dmscpu's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: slevin1
Saul
That was the first thing I did.
I too have had good luck with wanted adds.
dmscpu is offline
Old 03-18-2012, 10:27 AM
  #243
superpuma332L1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi everyone..
I hope that this Summer all Molds of my Adam A 500 are ready , and so itĀ“s possible to get parts from me....
Best reagrds M.Gross
Old 03-18-2012, 05:22 PM
  #244
Thisstrangeengine
Thisstrangeengine's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If only I had the space...
Thisstrangeengine is offline
Old 03-19-2012, 10:18 AM
  #245
superpuma332L1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Space =??
Best regards
M.Gross
www.m-gross.com
Old 04-16-2012, 09:24 AM
  #246
superpuma332L1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are the next steps of the fuselage ( part one of the mold)
Done with
1. Mold resin
2. 1 Layer of 163g Glasfibre
3. 2 Layers of 280 g Glasfibre
4. 3 Layers of 580 g Glasfibre
5. 2 layers of 280 g Glasfibre
6. 1 Layer of 163 g Glasfibre
7. Mold resin
3,5 kg of Resin/Hardener Epoxidharz EP-Harz E55L and Glasfibre from www.hp-textiles.com
ID:	1751148   Click image for larger version
ID:	1751149   Click image for larger version
Old 04-23-2012, 09:59 AM
  #247
superpuma332L1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Now the second step of the fuselage mold is done...on Sunday 22.4.2012
Today i open the mold ,to look if everything was allright...yes itĀ“s okay and the original fuselage made it also....
Following some photos of the complete mold from outside and inside
Next step will be a mold for the two firewalls.....
Coming soon on this channel
M.Gross
aircraftmechanic/aircraftbuilder
ID:	1753999   Click image for larger version
ID:	1754000   Click image for larger version
ID:	1754001   Click image for larger version
ID:	1754002   Click image for larger version
ID:	1754003   Click image for larger version
ID:	1754004   Click image for larger version
Old 04-28-2012, 09:34 AM
  #248
superpuma332L1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi all
here are some Pictures of the cleaned mold...and whatĀ“s left of it.....
ID:	1755987   Click image for larger version
ID:	1755988   Click image for larger version
Old 05-03-2012, 04:29 PM
  #249
Xairflyer
Xairflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is this kit still available
Xairflyer is offline
Old 05-03-2012, 07:32 PM
  #250
superpuma332L1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes i think www.eurolight.aero in Germany has it on its homepage.
my kit i took from the boss of eurolight over ebay for 289 ā‚¬..........
The quality was okay but not for me.......
i will rebuilt this kit on my ideas.......Carbon or Aramid fuselage with 3 mm honeycomb and booms and wings in full carbonfiber with Herex sandwich(wings)....
i expect to gain the original weight from 7-8 kg MTOW...not the 10-11 kg like mentioned here
Best regards
M.Gross
aircraftmechanik/aircraftbuilder
Reply
Display Modes
