If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 54 of 93 FirstFirst ... 444525354555664 ... LastLast
Results 1,326 to 1,350 of 2319
  1. #1326
    Join Date
    Apr 2006
    canberraact, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KMP F-7F Tigercat
    And some more
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1162269   Click image for larger version.
ID:	1162270   Click image for larger version.
  2. #1327
    CHARLES WINTER's Avatar
    Join Date
    Jan 2002
    MERCED, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Scale9, What size engines are you using, they look VERY small for this size airplane. I had originally used 2 RCV 90 engines and they were not at all adequate. Also using 1 (one) servo on the elevators and that common wire connecting both elevators may not be a SAFE design. Something to think about. Col. Chuck Winter
  3. #1328
    Join Date
    Apr 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Charles the motors are thunder tiger 91 2 strokes i am useing 13 kg servos carbon fiber inner with brass outer for push rod very strong no give unlike my p38 i have broken one already that one had 91 4 strokes in it
  4. #1329
    ghost.fr's Avatar
    Join Date
    Apr 2008
    monaco, MONACO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    the top of the wing with the air filler so easy access and idden
    P51 182cm 150saito
    Corsair 192 cm 120OS
    F7F twinSAITO 115
    dauntless saito170R
    FUTABA 12FG
    http://gallery.me.com/gromano
  5. #1330
    Join Date
    Jun 2002
    Rochester, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It's on the wheels! and one prop 19x10 graphite prop.
ID:	1162377   Click image for larger version.
ID:	1162378   Click image for larger version.
ID:	1162379   Click image for larger version.
ID:	1162380   Click image for larger version.
    RON McGRATH
  6. #1331
    Join Date
    Jun 2002
    Rochester, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    A few more pics of the build along the way!
    RON McGRATH
  7. #1332
    Join Date
    Jun 2002
    Rochester, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ok a little smaller.
ID:	1162386   Click image for larger version.
ID:	1162387   Click image for larger version.
    RON McGRATH
  8. #1333
    Join Date
    Jan 2002
    MERCED, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Scale 9 (Don't know your first name) Thanks for your response. If your Tigercat weighs-in at the weight many other Tigercat owners have -25 to 30 lbs, I feel you may be VERY low on power with 90 size engines for safe flight and for sure if you loose and engine in flight you will have basically no power for possible flight to a safe landing. The other subject is your control of the elevator with one servo. What many modelers forget, is that one of the Primary reasons for two servos is if you have one servo go BAD you have a back-up servo to get YOU HOME for another day. Another Plus for a second servo is the ability to adjust each elevator so you have similar trim position of each elevator. Have FUN, press-on and keep us up-dated with your project. Col. Chuck Winter
  9. #1334
    Join Date
    Jan 2002
    MERCED, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ron, Very impressive installation of all components, but my MAIN question is "How do you keep your workshop so NEAT". Col. Chuck Winter
  10. #1335
    Join Date
    Jun 2002
    Rochester, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You have a neat freak build it in their shop I just pay for it! Lucky for me, A good friend of mine is doing the build. We hope to have it done for the Nall and will finish up the year at the NEAT FAIR (barring any problems)with lots of meets in between. Both of us belong to traveling R/C club named the R/C Gypsies. Here is a link to the meets we attend in the western New York area. Always a Great time camping at the feilds!
    http://www.rcgypsies.net/calender.htm
    RON McGRATH
  11. #1336
    F82FAN's Avatar
    Join Date
    Jul 2002
    Conroe, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: CHARLES WINTER
    Hi Col.,
    We used a common wire elevator joiner on mine and it has numerous flights at full tilt with a pair of YS 1.20AC's wailing away on each side. We used a nice thick 5/32" piano wire and it is working fantastically. MUCH safer (IMHO) than the flexible pushrods that were included with the kit...
    I'm using a strong digital servo and a carbon fibre rod with 4-40 titanium ends as the pushrod and it is rock solid.
    The common joiner assures that both halves stay aligned - so no individual trimming is needed.
    The only issue would fall under redundancy, but I can say that, in all my years of doing this, I've not had a quality servo fail on a flight control - ever. Doesn't mean it can't, just that it hasn't. I've had old, cheap servos stop working when used as a gear actuating servo, but never a digital...
    I do agree about the power issue. If one of those .90's goes away, I wouldn't want to be at the sticks either!
    HANGAR.... YOU KEEP PLANES IN THE HANGAR!!!!
  12. #1337
    F82FAN's Avatar
    Join Date
    Jul 2002
    Conroe, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Ron McGrath
    Hi Ron,
    Good thing you sprung the dough for the Sierras up-front. You will NOT regret it. You also won't ever know HOW much you have missed out on in terms of frustration by doing them from the start!
    Looking great.
    I would love to hear what a pair of 19" 3-bladed props sounds like up there. WOW!
    Keep us "slimer" boys updated. I'd like to know what your all up weight is with batteries when you are ready to fly.
  13. #1338
    Join Date
    Jun 2002
    Rochester, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    With any luck It will be under 30lbs The first setup we were considering would have weighed 2.25lbs less. this is much closer to scale props I think we will end up with 18x10 3 blade Mejzliks that will be in the 6.5 to 7 hp range or 5000 watts/ 166 watts per pound.
    I am surprised no one has noticed the wing tubes.
    RON McGRATH
  14. #1339
    F82FAN's Avatar
    Join Date
    Jul 2002
    Conroe, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    That's enough electrons to blow my head off of my shoulders! Woo Hoo, it should go good.....................................
    I noticed that it looks like it's from a Hangar 9 Extra 260 ? Why didn't you mount the tube in the outer panel to REALLY shorten the span??? I guess every bit helps... Not being critical - just askin
    You've got Watts n Gear Doors - I've only got the Sierras!
    Regards,
    Wally
  15. #1340
    Join Date
    Jun 2002
    Rochester, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The wing tube is not attached to the outer or inner wing it just slides out of the center section for easy storage.
    RON McGRATH
  16. #1341
    Join Date
    Mar 2009
    Wognum, NETHERLANDS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Foks,
    Here some pix of mine F7F tigercat....
    It's ready to go...
    airframe: KMP
    engines: 2 x OS FS 200
    prop 16 x 8
    Landing gear: Sierra
    weight: 12, 5 kg
    Soon some pix of the maiden flight will follow...
    regards,
    Ton
ID:	1163107   Click image for larger version.
ID:	1163108   Click image for larger version.
ID:	1163109   Click image for larger version.
ID:	1163110   Click image for larger version.
ID:	1163112   Click image for larger version.
ID:	1163113   Click image for larger version.
ID:	1163114   Click image for larger version.
  17. #1342
    Join Date
    Mar 2009
    Wognum, NETHERLANDS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Cat boys,
    here some more detailed pix of the inside.....
ID:	1163122   Click image for larger version.
ID:	1163123   Click image for larger version.
ID:	1163124   Click image for larger version.
ID:	1163125   Click image for larger version.
  18. #1343
    Join Date
    Jan 2002
    MERCED, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Ron & Ton, Great pictures from both of you CAT guys. It's always interesting how MANY different approaches are taken to solve a similar problem. I think that is what makes this hobby FUN and at times Very Frustrating. GOOD SHOW guys. Col. Chuck Winter
  19. #1344
    F82FAN's Avatar
    Join Date
    Jul 2002
    Conroe, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    AAhhhh, good deal!
  20. #1345
    Join Date
    Jun 2002
    Rochester, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I like the scale art work on the nose gear door. The linkage to the door is very creative. Tongoede, have you flown your Tiger cat yet? Also, did you reinforce the center section of the wing were the wing tubes are I noticed you did cut several holes in the fiberglass sheeting for the equipment installation are you worried about it being weakened ?
    RON McGRATH
  21. #1346
    Join Date
    Mar 2009
    Wognum, NETHERLANDS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello Ron,
    No , the bird is still waiting for its first maiden flight.
    I need a big enough airstrip for trying out.
    Our Clubfield is maybe big enough, but I am not sure.
    I think the cat needs a big landingfield because of the wing/ weight ratio.
    I don't think T/o will be a problem....Power enough...
    I did reeinforce the center wing section, so I am not worry about the strength...
    Engines now are running very reliable and smooth.
    I am using a twinsync system from rc showcase with the glowsystem together, and its working very nice!!!!
    I also made my wingtip sections seperate, for easy storing and easy transport.
    I am using the 2 receiver system of ACT, so all servo's are individually programable. together with the power box and 2 x 5 cell 2400 mAh batteries all works very nice!
    Now, lets hope it will fly nice too!!!!! You know what they say; when it looks right , it flies right!!!!
    Ton
  22. #1347
    Join Date
    Jun 2002
    Rochester, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Tongeode
    How did you reinforce the center section of the wing? and what RPM do you get on the 16x8 3 blade master airscrew prop? I was roing to use 16x10 3 blade master airscrew but decided to go with a 18x10 mejzlik after doing some testing on the ground.
    Also.......................I like the white gear!
    RON McGRATH
  23. #1348
    Join Date
    Mar 2009
    Wognum, NETHERLANDS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello Ron,
    Yes the gear has been painted white....just as the original...
    The center section of the wing is reiinforced with two multiplex spares with carbon strings.It looks a lot like the reinforcement of col. Chuck Winter....
    The rpm on the master airscrew 16 x 8 is around 8800 Rpm....
    Power enough I would think[&:]
    He Ron aren't You are going to use the carbon 19 x 10 prop? looks awefully cool on the cat!!!!
    What kind of motor are you going to use?
    cheers,
    Ton
  24. #1349
    Join Date
    Mar 2009
    Wognum, NETHERLANDS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    He Ron,
    Here some more pix of the wing tips ....
    the alu. tubes are fixed in the wing tip part, and when mounted they are going through the nacelles to the center wing part, where they are mounted with a nylon M4 bolt.
    cheers,
    Ton
ID:	1164306   Click image for larger version.
ID:	1164307   Click image for larger version.
ID:	1164308   Click image for larger version.
  25. #1350
    Join Date
    Jan 2002
    MERCED, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Ron, Question Did you make the Nose Gear Door stand-off unit (Looks like brass) that engages the TRACKS in the Nose Gear Door. I have my Sierra Retracts working well and holding 100 PSI for many hours in the UP and Down position. Hope to get another flight in tomorrow. If all goes well I want to re-attach all my doors but have to make a Nose Gear door Pulling Unit. Thanks Col. Chuck Winter
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
