Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Palmer 132" AC-130 Build
Reply
Old 03-17-2015, 07:41 AM
  #1901
mlang1321
mlang1321's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Frank did you send to my email as well I never received any information from you. Let me know if you need my email address again.
mlang1321 is offline
Old 03-18-2015, 04:05 PM
  #1902
oltimer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mike;
Yes, please send me your email address. The reason you didn't get the articles I sent was that the file was too large. I will send it in two consecutive emails.
Sorry for the delay.
Regards, Frank
oltimer is offline
Old 04-03-2015, 09:38 AM
  #1903
soundfan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Little update. Made some good progress on the fuselage.
Main gear will get some changes. I never liked the idea that all weight of the aircraft is put on the shaft of the retract at the wooden main gear board.
I changed the board to a fibreglass board. The gear from century jets is far too expensive in my opinion. So I did my own.
The board will be operated via rotating shaft on a standard servo, like I've seen somewhere in this thread. The boards will be led in IGUS linear slides.
Front gear is fitted and operating.
http://youtu.be/JsjGUc2DJDg Area around the ramp is reinforced by carbon rovings as suggested by Oltimer (thanks for the hint).
Next step is motor testing tomorrow. I need to set all four ramoser 4 blade props to the same pitch so power will be identical on all motors.
To be continued...
ID:	2086041   Click image for larger version
ID:	2086042   Click image for larger version
ID:	2086043   Click image for larger version
ID:	2086044   Click image for larger version
ID:	2086045   Click image for larger version
soundfan is offline
Old 04-03-2015, 03:23 PM
  #1904
oltimer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mike;
I will try with the article once more.
Frank
oltimer is offline
Old 04-03-2015, 09:33 PM
  #1905
soundfan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Frank,
thank you again, but I received it the last time already. I replied to you immediately but obviously you didn't get my answer.
Or have you mixed up all the Mikes in this thread?
Thanks for your support anyway!
BR
Mike
soundfan is offline
Old 05-01-2015, 08:40 AM
  #1906
soundfan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi folks,
I know, progress is very slow. But finally I have finished my servo powered main gear retract. Works great and very smooth.
No force on the servo in gear down position. All energy from landing is led to the frame, nothing to the servo gear.
http://youtu.be/Q2JL5L5Yx8g http://youtu.be/Uw-4pbEOMrU To be continued...
Regards Mike
soundfan is offline
Old 05-01-2015, 09:07 PM
  #1907
ir3
My Feedback: (42)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Mike,
The landing gear is excellent. That is where I was on my Herc when I passed the project on to another builder. I think it is one of the best parts of the entire build. It makes me want to do another.
Keep up the great work and keep posting.
Iran Ausley
ir3 is offline
Old 01-04-2016, 05:45 PM
  #1908
sweinhart2006
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi all. A few weeks ago I started on my palmer 133" C-130. I can't seem to understand a portion of the loading ramp related to the linkage of Arm A. The first picture shows the actual aircraft ramp down. The side of the ramp where the linkage connects is flat. The second picture shows the plans which suggest the connection is made in the curved portion of fuselage sheeting which doesn't make sense because this area of the sheeting will be glued to the formers on the side of the aircraft and does not move. The third pic shows the former the bracket is glued to connecting the ramp to its linkage but it does not reveal where this former is place. The 4th pic shows the former or sides of the ramp and above it in squiggly lines is the curved former where the bracket is glued to, but again does not show where or how this is applied to the ramp. There is nothing like this piece in my kit, which is no surprise coming from kitcutters. Iv'e had to modify a number of items to get them to fit right and other pieces seem to missing as well. I'm hoping someone on here who has built the ramp knows where this curved piece goes. I assume I need to make two of them.
ID:	2139750   Click image for larger version
ID:	2139751   Click image for larger version
ID:	2139752   Click image for larger version
sweinhart2006 is offline
Old 01-05-2016, 04:19 PM
  #1909
oltimer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mr. Sweinhart 2006;
Please send me your Email address in a personal reply and I will assist you with this problem.
Oltimer
oltimer is offline
Old 04-06-2018, 01:28 PM
  #1910
noobdude
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by oltimer View Post
Mike;
Regards, Frank
hi frank
i am reading this thread and working on a fiberglass c130 project. its still in drawing phase, I read somewhere you mentioned that you made many of your parts your self from fiber and also you skinned your wing in just fiber, can i have some pictures of your parts and specially that Fowler flap design. thanks in advance.
noobdude is offline
Old 04-15-2018, 06:33 AM
  #1911
troytibbs
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have the same kit from precision. Does anyone know where I may find the building instructions for it?
troytibbs is offline
Old 05-11-2018, 12:57 PM
  #1912
Zeppelin1275
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Palmer plans and instructions !! Its very much down the builder to figure it out, I had a F7F plan set from Palmer.. They were mind boggling ! good luck !
Zeppelin1275 is offline
Old 09-19-2018, 12:26 PM
  #1913
Jorihuela27
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anyone here looking to sell there C-130 Hercules I'm looking for an ARF or a good conditioned RTF
Jorihuela27 is offline
Old 05-24-2019, 10:58 AM
  #1914
TomZawodny
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My brother & I are each looking for a set of Century Jet retracts for the Palmer 1/12th scale (132" WS) C-130. Looks like CJM (the recommended source) is for sale due to the retirement of the owner. Does anyone have a set (or 2 ???) for sale ???
TomZawodny is offline
Old 05-26-2019, 09:18 PM
  #1915
krles
krles's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Didn´t You thought about DIY it?
LOCKHEED C-130 Hercules landing gear on DVD
krles is offline
