Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Top Flite Cessna 310 posted
Reply
Old 09-03-2018, 04:27 AM
  #3851
Smotherb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Bisson mufflers
Originally Posted by turnnburn View Post
I need in order of importance:
1 each Bisson 4046 pitts Stlye Muffler
1 set of exhaust stack muffler extensions as used on above muffle for TF C-310. I forget who made them, I don't think it was Bisson.
1 each OS ,46ax prefer NIB or gently used.
i tried to reach out to the company for the muffler extensions but the owner has passed away and now they are unable to locate the prints for the extensions. I found the mufflers straight through Bison! I just finished my plane with the OS 55’s and really like it! I guess I’ll strengthen my wings a little after all I have read but I plan on greasing all my landings, lol
Smotherb is offline
Old 09-03-2018, 04:28 AM
  #3852
Smotherb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The company that made them was LEX Aire
Smotherb is offline
Old 12-17-2018, 04:35 PM
  #3853
turnnburn
My Feedback: (49)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Wanted , Bisson Muffler screw on exhaust extension
I built my TF 310 back in 2006 or 2007 when they first came out. I use Os .46ax engines with Bisson pitts style mufflers. Back when I built it there was a gent (RCU screen name Meesh) who was making and selling thread in exhaust extensions for the bison muffler. The builder of the model was too cut off all but about 3/8 to 1/2" of the muffler exhaust tubes. Then they were to be tapped with a 9mm x1.0 tap. What this did was allow the entire nacelle to be slid on and off without getting hung up on the stock exhaust tubes which stuck down well over one inch. The engines with the bison 4046 muffler with all but 3/8" or so of exhaust tubes cut off were mounted on the mounts and then the nacelle slides over and is screwed in place. Then the threaded exhaust extensions and threaded on.
Well I recently stripped the threads on one of my four Meesh made extensions. He no longer makes them.
I need ONE. HELP. Anybody have one from a new set or a crash that they are not and will not be using ????
turnnburn is offline
Old 01-19-2019, 04:13 AM
  #3854
rowdog_14
rowdog_14's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I saw a few post about the Saito 90ts. I am guessing no one put those in?
rowdog_14 is offline
Old 01-30-2019, 05:47 PM
  #3855
rowdog_14
rowdog_14's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just wondering if I am correct. Are the Nacelles 172mm wide? Looking to add some 90ts in and they are 170mm wide.
Old 02-05-2019, 04:34 PM
  #3856
rowdog_14
rowdog_14's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got my C310 in today and yes they are 172mm wide at the widest point but tapper down to about 165 towards the front . So much for using two 90ts . The Saito 60t will fit though, but doubt power will be adequate.
On another note why in the world did they put the nose weight IN!!! that sucks. They should have just given you the lead and glue and made it optional.
Old 02-09-2019, 06:37 AM
  #3857
Appowner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by Rotten40851 View Post
Finally re-maidened the 310 with the DLE 20's on her. Flew like a champ. Stable, plenty of power in reserve and sounded sweet. Plane is awesome. For all who said DLE 20's are too much. Sorry to disappoint you. The plane flies better than ever. https://youtu.be/N2NoDMN3hEg https://youtu.be/hSOqjqmvjnA https://youtu.be/1tzw7FC-x4M https://youtu.be/9D0MI1ew6v4
Looks like a pretty fast landing there. Won't it slow any more?
Appowner is offline
Old 02-14-2019, 12:27 PM
  #3858
rowdog_14
rowdog_14's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You just had too ...
Old 02-14-2019, 06:03 PM
  #3859
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Most of us are aware that it's solid practice to land a new airplane a bit on the fast side until we get a feel for it.
speedracerntrixie is offline
Old 02-14-2019, 06:32 PM
  #3860
rowdog_14
rowdog_14's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
appowner is sooo reaching to find something to support his statements in another thread. I find I just have to chuckle at his effort .
Old 02-14-2019, 07:30 PM
  #3861
speedracerntrixie
My Feedback: (29)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
5 years ago I started participating in some local Warbird pylon racing. We were putting YS 115 engines into WWII fighters with 515 Sq in wings. Some of these airplanes would weigh up to 7.5 pounds. I consider that a fairly heavy airplane yet they land no faster then an old school pattern airplane. One of the biggest reasons is the correct CG. That's why I focused my comments on your other thread around the CG. Think about a heavy pylon airplane pulling 20 G with no tip stall tendencies. It's usually not an issue when you have the knowledge to correctly set up an airplane.
Old 02-18-2019, 06:21 AM
  #3862
Appowner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The proof of the pudding is in the flying. You do what you want and we'll see what happens.
You asked for opinions. I gave mine. I pointed out that with your initial engine thoughts you were pushing things. You didn't like that so you proceeded to accuse me of saying things I did not say. Now you try to pass stories about me while I've said nothing more. Who's reaching?
I see the potential for problems and issues some of which I have read about in other threads for this very model where larger engines were used. But hey, what do I know? Been in model aviation for over 60 years now. You obviously have the upper hand here.
Appowner is offline
Old 02-18-2019, 07:55 AM
  #3863
rowdog_14
rowdog_14's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Opinions are great and I take them as need and as they are presented. You did not provide an opinion in our first post. Then you make a generalized statement of assumptions which based on your 60-year knowledge you state above you know is not true for all cases, see below for a few examples. As far as accusing you…where do you see that? I directly referenced statements you made in the other forum. Stories what stories? I asked if you wanted to continue you could PM directly. You decided to post in the TF C310 thread…why I do not know. Now mudding up this forum…
Again, you referenced things on the TF C310 as general assumptions and not actual knowledge please see your post from the other forum. I am happy you came to this TF C310 thread and read around. In aviation and RC there are some generics that apply to all plans and some that are unique to specific types of planes. Example, there was a pilot that came to the local airport that I teach ground school to talk about his career as a show pilot in a turbo prop transport plane. At the end he said he could help as needed but he did not know a lot on general aviation. He just did not throughout general statements.
I understand your concern with larger engines, but I must ask with your 60 years of model aviation how much of this is with scale planes? I asked because with scale model they require considerably more nose weight than other RC planes. About 90% of my planes are scale models, and with all I always run into issues with needing nose weight. Instead of adding dead weight people normally add a larger engine. Examples:
My TF Staggerwing needed lbs of nose weight to get it to balance. In this case I would have been better to add a bigger engine instead of going with the suggested engines by TF and adding all the nose weight.
My H9 P-47 I added a DLE 55 which is 25cc more than H9 suggest but balances it out perfect without having to add weight.
My GP GeeBee. I needed to add a heavy nose spinner weight to the very tip of the engine shaft. I would have been better to use a larger engine that suggested in the manual instead of dead weight spinning on the engine. If I did not add to the very tip I would have had to add way more weight on the firewall.
This same applies to the TF C310. Therefore, they added all that lead in the nose.
I can keep going if you want. I also have videos if you need…Also years, does not directly correlate to experience.
Thanks and my offer still stands you can PM me instead of us mudding up these forums with this.
Old 02-18-2019, 08:11 AM
  #3864
Appowner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have nothing to say to or about you. I suggest you do likewise.
Appowner is offline
Old 02-18-2019, 10:12 AM
  #3865
rowdog_14
rowdog_14's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh I never had any intention to reach out to you so you do not have to ask me to do likewise, I just offered it up to you in the other thread.
Old 02-19-2019, 12:59 PM
  #3866
Robby
My Feedback: (18)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gentlemen.......
As you may know I am the MOD for this forum...
As you may also know I have the power to make things happen..
So, gentlemen, I am at this time asking you to refrain from any further
negative discussion in the forum.
You may take it into PM's as I do not deal with those..
The last two post in this forum should be either deleted or changed into a positive comment.
I think you gentlemen know what you should do...
Thank you,
Robby
Robby is offline
Old Yesterday, 08:51 AM
  #3867
rowdog_14
rowdog_14's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by robby View Post
gentlemen.......
Robby
