Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
ELectric Twin Engine Setup
Reply
Old 01-03-2008, 10:35 AM
Slowjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: ELectric Twin Engine Setup
I'm at a loss to suggest anything else other than to maybe move this over to the Electric forums. I think you'd get more response over there and just maybe someone has run into your problem before. There's some pretty sharp folks there. If I have 4 wires, 2-White and 2-Black to connect, I'll cross 'em at least once. Maybe Twinman will chime in and move this over for you. What you think Twinman?
Standing By,
SJ
Slowjohn is offline
Old 01-03-2008, 11:31 AM
vmsguy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It sounds like you have all this in your airplane.
I know it's work, but if I may suggest, take your motors, battery, ESCs and receiver out of your plane and put it on a test stand. Leave the props OFF. If you have to build a small test stand, thats OK too.. Better a little extra work now, then a broken plane later.
Then, with the elements on a test stand you can make sure the wiring is correct, and trouble-shoot it better.
Good luck,
vmsguy is offline
Old 01-03-2008, 11:47 AM
Slowjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just emailed & asked my Motor/ESC Guru to take a look at this and let me know what he thinks might be the problem. I'll post ASAP if he's got any input.
Standing By,
SJ
Slowjohn is offline
Old 01-03-2008, 11:54 AM
Mr Electric
Mr Electric's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
THANKS
Mr Electric is offline
Old 10-26-2018, 12:57 PM
quickpix
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Seagull Cessna 337 push pull arf motor thrust angle
I am having difficulty finding the straight info on motor thrust angles on a this push/pull plane.
Nothing in the manual addresses it.
What say you?
quickpix is offline
