CL 215 form KMP
CL 215 form KMP
Is there any news about the new CL 215 from KMP. It is susposed to have a 80" wing span and take 2 - 60 sixty 2 strokes.
Fiberglass fuse and built up wing.
1 Post
RE: CL 215 form KMP
Reccomended engines are .60 4 strokes such as the RCV-60SP they KMP import.
They posted a video but not much more infos. .. it seems just fine to practice those funny splash-and-gos with a sport-scale twin!
http://www.kmp.ca/product_info.php?c...0457bd880319ff
ON, CANADA
1 Post
RE: CL 215 form KMP
I saw then at the Hobby Show couple weeks ago, they had 215 there, its was excellent looking model, they siid its been discountined for newer version CL-415 which they said should be out in couple of months time frame.
RE: CL 215 form KMP
HI Guys:
Just to clear up some possible confusion... The CL-215 is brand new and has not at all been discontinued. In fact it hasn't even been released yet. The first batch is showing up around the end of February. We hope to make a CL-415 as well but that is off in the distance as of now. The CL-215 cowls are much better for cooling. There should be a few more pictures posted on the site now... under the KMP "sport series" I have posted here an actual picture of the model we had on display at the Canadian Hobby Show in Toronto.
RE: CL 215 form KMP
That is excellent news. I have put my deposit down on one at the local hobby shop. Also ordered 2 60 size RCV engines. Lots of time to assemble before the water unhardens in this part of the country. O well back to the Bobcat for now.
RE: CL 215 form KMP
Its a true Canadian classic for sure.... Its awsome to see these (full scale birds) beeing used worldwide and to very good use. Hopefully they (the model) will sell well all over the world
What did you think about the video?
1 Post
RE: CL 215 form KMP
Hi Andrew!
Just a question: the prop hub in the pic are Tru-Turn TTH-1000-A ?
http://www.truturn.com/cgi-bin/store...exact_match=on
Thank you.
Thank you.
AB, CANADA
RE: CL 215 form KMP
video...schmideo......I want the real thing!!!! Cool that you have chosen to do the classic 215. It has got that hairy chested, work horse, stake bed truck look...... much more purposeful than the dainty looking 415!!
MT
RE: CL 215 form KMP
Andrew
is your CL 215 going to be able to pick up water? I built one from RCM Plans and it will pick up about a quart of water and drop it. It is pretty cool. I do like yours though, it looks a lot more scale than mine.
Ron
Ron
RE: CL 215 form KMP
Hi Guys:
A couple of things...
First the hubs I used were the 1.25 flanged (not sure on the number) We stock them and sell them with the props and engines.
Second, unfortunately this model as its made can not pick up water. I am sure that with some enginuity one can create the system to do it but for now that is an aftermarket project.
The plane can easily handle a significant payload though... its quite light and has a large high lift wing so it is well within what the plane is capable of handling as additional weight.
1 Post
RE: CL 215 form KMP
ORIGINAL: AKondor
Hi Guys:
Hi Guys:
Thank you for the info Andrew.
TX
RE: CL 215 form KMP
Mine is on order as well. February seems a long time away. In the meanwhile, I'll keep playing with the Mariner. In Fort Worth, it's a year round event
RE: CL 215 form KMP
year-round eh!..... lucky you. This morning it was -14 C. All hopes of water flying are gone now until Spring up here. 8 cm of snow expected tonight. Maybe its a good thing the plane can fly of snow too
My Feedback: (24)
RE: CL 215 form KMP
LOL... In 1974 I took a trip in May from Virginia up to Ontario, and then west to BC. I drove through Thunder Bay, and it took three days of driving around that giant lake before the great lake ice even started to look broken up! Even as I crossed Canada, I still could see Piper Cubs parked on the ice in the middle of small lakes (ponds to you guys). In the middle of May!
RE: CL 215 form KMP
On my way home from our Nov. model aircraft meeting the temp read -29 degrees C.
Thats at 9:00 pm so I would think we should hit -30 easy tonight.
TX
RE: CL 215 form KMP
I saw on the website that this aircraft uses 13 servos. I can't figure out where it can use them all. Depending on configuration, I can only see 8-10 at the most. Can anyone enlighten me?
RE: CL 215 form KMP
hI Guys:
2 - Ailerons
4 - Flaps
2 - Throttle
2 - Elevator
1 - Rudder
1 - water rudder
I guess thats 12.... Need to take another look why the factory says 13.
2 - Ailerons
4 - Flaps
2 - Throttle
2 - Elevator
1 - Rudder
1 - water rudder
