If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 50 of 61 FirstFirst ... 40484950515260 ... LastLast
Results 1,226 to 1,250 of 1505
  1. #1226
    Join Date
    Dec 2011
    center, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE:
     Bill and Allen
    Thanks for the welcome, and I am very glad to be a part of this club. I already have a few questions to ask.
    Are there any options for retracts other than robart? (little pricey)
    Earlier in this forum i saw where someone used what looks to be 3/8 alumiunm tubing for the joints just outside of the engine nasels on a 3 peace wing. Was wondering how that turned out and if it was strong enough? Our part finished 310 has been done in a similar way, wing flexing is my concern and didn't know if it needed a total re-model to a one peace version or larger wing tubes.
    Thanks, Ethan
    Thanks for the help, Ethan
  2. #1227
    bps's Avatar
    Join Date
    Oct 2002
    Indianapolis, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE:
    Greetings Ethan
    Not meaning to cut in here but I like the carbon fiber wing tubes located here http://www.troybuiltmodels.com/categ...par-Tubes.html this company is just one of many that sell cf tubes. I have read accounts of problems with the aluminum tubes not fitting well and causing wing wag.
    If you check back just a few posts you will see where one builder has ordered a retract set from Hobbyking. I am waiting to see just how these work out as they are much less expensive. Hope this helps.
    JEB
    Giant Scale P-47, Knight Twister, 33% BD-8, 40% Gee Bee Z, 25% Dr1, 25% Clip Wing Cub, #45 Bud Nosen 310 Club
  3. #1228
    Bill Diedrich's Avatar
    Join Date
    Jul 2006
    Ventress, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    ORIGINAL: FlyBoy.15
    Β*Bill and Allen
    Are there anyΒ*options for retracts otherΒ*than robart? (little pricey)
    Earlier in this forum i saw where someone used what looks to be 3/8 alumiunm tubing for the joints justΒ*outside of the engine nasels on a 3 peace wing. Was wondering how that turned out and if it was strong enough? Our part finished 310 has been done in a similar way, wing flexing is my concern and didn't know if it needed a total re-model toΒ*a one peace version or larger wing tubes.Β*
    Thanks, Ethan
    Ethan, the aluminum wing tubes are of the original design, check the plans from the other kit that you have and you will see
    that is the way that Bud Nosen designed this aircraft, for ease of transportation, the outer panels are detachable. There is not
    a flexing problem with this system, as long as they fit without a lot of slop, but if you decide to go with retracts you will more than
    likely have to notch the tubes for wheel clearance, check back through the thread and I think you will find a picture posted showing
    this. A one piece wing is a huge undertaking, yes it is stronger, but remember this plane has a 10 foot wingspan, it would be like handling a long
    "surf board", not to mention transporting that massive wing.
    On the question of retracts Robart I have been told are the best for this model but, I think that Sierra Giant Scale made a set
    for the Nosen 310 at one time but they aren't shown on the web site anymore. Centry Jet Products has gear for this aircraft
    but they are just as pricey as the Robart's. Spring Air also made a set that was suitable for the 310 but I haven't been able to
    find them on their web site either. Check back on the last couple of pages, one of the group has ordered a gear set from Hobby
    King for there 80cc T-28 and is waiting on them arriving to see the quality of the product. But just remember that if you put all
    of this time into a model of this size you don't want to cut cost on one of the most important areas of this aircraft.
    Bill D.
    Founder \"Nosen Cessna 310 Club\"
    Waco Brotherhood # 43
    P-39 Brotherhood # 5
  4. #1229
    bps's Avatar
    Join Date
    Oct 2002
    Indianapolis, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE:
    Hey Bill how are you doing with the glass fuse? I am interested in this option, looks like it can save some weight.
    JEB
  5. #1230
    Clavin01's Avatar
    Join Date
    Apr 2004
    Glen Burnie, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    Hey Flyboy
    I believe you might be looking at some of my Pics, about the 3/8 Alum Tubes, If your wing is not built yet do the mod and use a larger tube
    for the joints. Mine are about 3/8 tubes with Solid steel in the centers to stiffen them up. However they do flex a little bit when moving on Grass
    my field is all grass with a runway and taxi ways cut down to 1" and the rest is 2" if I put retracts in it I will use a larger tube and socket
    with alignment dowels front and rear. as far as attaching the outer wing panels the Plans show 2 screws throught the tube under the nacelle.
    I modded mine to a single bolt between the tubes with a solid hardwood block in the outer panel and tapped for the bolt, to tighten the bolt
    I have a hatch on the nacelle that i can open to get to the bolt. Hope this shed some light on the subject for you. If you have any questions
    Let me know. Thanks Cliff
    Nosen Cessna 310 Club #56
    Cub Brotherhood #243
    Waco Brotherhood #252
  6. #1231
    Thisstrangeengine's Avatar
    Join Date
    Jun 2009
    Douglassville, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    Welcome Flyboy...
    Nosen Cessna 310 Club Member #54
  7. #1232
    Join Date
    Dec 2011
    center, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE:
    Again, thanks for the welcome. Will enlarge the wing tubes but never thought about using cf insted of alumnium, do want to keep the easier transportation of the 3 peace wing. Will do some more looking on retracts with Bill's point in mind.
  8. #1233
    Join Date
    Jul 2006
    Ventress, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    ORIGINAL: bps
    The glass fuselage is definately the way to go to save weight, I am still in the wing center section mod that I have been
    working on, which involves moving the wing tubes both forward and aft of the positions shown on the plans, as I have
    recently received a set of landing gear I can now move forward on this project. I will finish the wing and tail feathers
    before moving onto the fuselage, although I have been doing some prelim sketches to include the full cockpit kit from
    Bob Dively Models.
    Bill D.
  9. #1234
    AmishWarlord's Avatar
    Join Date
    Oct 2002
    Indian Trail, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    Hobby King T-28 gear came in today. That didn't take long.
    The gear looks OK. Not as good as Robart's but not bad for 1/5 the cost.
    The welds look OK. I'll get a better look later when I bead blast the primer off.
    The nose gear indeed is not 90Β°. It's not out as far as the 310G's but it dose stick out.
    Main gear are a little long and will need to be trimmed.
    Just by mocking up the gear locations on the plans it looks like they will be a good fit.
    I was a little worried that they would be to large and heavy since they are "80cc" gear.
    However my first guess was right. Hope the T-28 guys make nice smooth landings.
    So for right now they look nicely made. I won't trust the air fittings though. I'd buy a name brand set if I was going to use them with air.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1763483   Click image for larger version.
ID:	1763484   Click image for larger version.
ID:	1763485   Click image for larger version.
ID:	1763486   Click image for larger version.
ID:	1763488   Click image for larger version.
ID:	1763489   Click image for larger version.
ID:	1763490   Click image for larger version.
  10. #1235
    Join Date
    Oct 2002
    Indian Trail, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    Last night I remembered the wing dihedral angle. The main gear just might fit without trimming do to them being mounted higher as the wing angle rises.
  11. #1236
    bps's Avatar
    Join Date
    Oct 2002
    Indianapolis, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE:
    If these fit I must order a set. One can do a lot of mods for the price difference.
    JEB
  12. #1237
    Join Date
    Jul 2006
    Ventress, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    Amish once you bead blast the primer off, let us know if the joints are braised or weld joints,
    I would do some filling tig welds as these joints look suspect,if they are welded, especially the
    nose gear.
    Bill D.
ID:	1763905   Click image for larger version.
  13. #1238
    Join Date
    Jul 2006
    Ventress, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    ORIGINAL: AmishWarlord
    The nose gear on ther full size Cessna 310-G model is 105 degrees, the wire gear shown on the plan is
    a bit exagerated, I think Bud did that to give it the rake that is a charater of the 310 nose gear.
    Bill D.
  14. #1239
    Join Date
    Apr 2005
    Taylorsville, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE:
    Any word on the gear fit and function? I could probably afford a set of these pretty quickly, and get busy on my 310!
    Bryan
    Nosen Cessna 310 Club Number 12
  15. #1240
    Join Date
    Jul 2006
    Ventress, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    ORIGINAL: warbirdmustang
    Bryan
    Bryan you will have to wait a bit they are currently on back order, go to the Hoby King site and do the "e-mail me when they
    are available" request so you can jump on them quickly when they get them back in again.
  16. #1241
    Join Date
    Oct 2002
    Indian Trail, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    I'm off on a side project WG.
    Working on an old hit and miss engine.
    Going to make a electric generator with it for a over sized field box.
  17. #1242
    bps's Avatar
    Join Date
    Oct 2002
    Indianapolis, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE:
    Anyone building? Very quiet around here.
    JEB
  18. #1243
    Join Date
    Jan 2002
    Sault Ste Marie, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    Na, this is flying season. My 310 is on display at the local mall, I"ll get back to it in the fall.
    The last thing I was working on was the air cylinders for the front gear doors, they worked out well.
    Happy flying, Terry.
  19. #1244
    bps's Avatar
    Join Date
    Oct 2002
    Indianapolis, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE:
    Yes flying season, only so much time to have fun!
    JEB
  20. #1245
    Join Date
    Jun 2009
    Douglassville, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    Same here, flying season is in full swing and I'm trying to finish an old project started WAY too long ago...
  21. #1246
    Join Date
    Jun 2009
    Douglassville, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    OK, I'm bummed out! I went out today to run some errands with the family, then took the boy to the park for some fun and when we got home I heard a pair of WW2 Radials in the distance. Now I know there is a WW2 Weekend at a local airport usually the second week of June, but thought I would check the website to see. Well it turns out the airshow is this weekend and the thing that bummed me out is the B-29 FiFi is there this year and I have to work Sunday, so I won't be able to see this rare Multi-Engine Beauty!! CRAP!!!!!!![:@]
    [link]http://www.maam.org/[/link]
    Here's another rare aircraft they have on display during the Airshow which is being restored to flying condition. I saw a documentary on the recovery of this plane and also saw the crates it was stored in several years ago at the Museum. Enjoy...and thanks for listening.
  22. #1247
    Clavin01's Avatar
    Join Date
    Apr 2004
    Glen Burnie, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    Well it finally happened, I maidened the 310 tonight.
    We have our annual Open House this Sat and any demo flights, the Plane must have flown
    previous. So out I went tonight What a sight and Sound it was fantastic.
    Required 2 clicks of up trim nothing else. What a relief it is done.
    I know it has taken a while since I posted it was ready, but had some family
    matters to deal with and had been stressed out. So doing a maiden
    was not a good idea at the time. Sorry did not get video on this one, but will have some on Sat.
    and will post it. Anyway the one thing it needs is retracts. Next on the priority List.
    Thanks to all for the Help here on the Nosen 310 Club.
    Cliff
  23. #1248
    bps's Avatar
    Join Date
    Oct 2002
    Indianapolis, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE:
    Nice!
    JEB
  24. #1249
    Join Date
    Oct 2002
    Indian Trail, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    She looks great Calvin!
    The screens on the cowling looks good also.
  25. #1250
    Join Date
    Jun 2009
    Douglassville, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    Yes she does look sweet! I can't wait to see some video, Just might give me some more motivation.
    I'm just about finished with my Morrisey Bravo and all that's left to do is mount the canopy, check final fit of everything, check the C/G and run a couple tanks of fuel through it befroe maiden.
    I was not going to go with retracts on the 310, but I think by the time I get back to work on it, I'll probably change my mind again. I have'nt sheeted the wing center section yet so it's not too late.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
