Go Back  RCU Forums > RC Airplanes > Twin & Multi Engine RC Aircraft
Reload this Page >
Any kit cutters cutting Duellist Mk.II from M.A.N plans?
Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Reply
Old 07-06-2009, 10:27 PM
JackL
My Feedback: (7)
JackL's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Any kit cutters cutting Duellist Mk.II from M.A.N plans?
Does anyone know of any kit cutters cutting Duellist Mk.II kits? I'm getting the plans from M.A.N. and would like to find a cutter for a short kit (or at least a set or two of wing ribs.)
JackL is offline
Old 07-07-2009, 05:15 AM
Robtck
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Any kit cutters cutting Duellist Mk.II from M.A.N plans?
Try laser works. If you send them the plans they can cut a short kit for you.
http://www.lazer-works.com/main.html
Robtck is offline
Old 07-07-2009, 08:00 PM
JackL
My Feedback: (7)
JackL's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just tried lazerworks, but they said the soonest they could get to it would be in the August-September time frame.
JackL is offline
Old 07-08-2009, 04:27 PM
mobyal
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check w/ Larry Katona at Precision Cut Kits. He does awfully good work.
mobyal is offline
Old 07-18-2009, 07:51 AM
TCBLightning
TCBLightning's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The way the ribs are "stacked" on the plans is kinda goofy and on the odd side the lines kinda cross and don't quite line up around rib 3. I was still able to cut sets for the two MK IIs I have built. If you run a little wide when cutting rib 3 you can clean it up with some sand paper and all is good.
TCBLightning is offline
Old 02-21-2019, 07:51 AM
NoOneFlysAtMyClub
My Feedback: (32)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
AMA Models on eBay sells the 2/40 and the 2/60 short kits.
NoOneFlysAtMyClub is online now
