Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Unusual R/C
Reload this Page >
Brushless ESC question for hovercrafts
Unusual R/C Discuss Airships, Blimps, LTA, VTOL, Ground Effect Vehicles, Hovercaft and more.
Old 06-13-2011, 02:38 PM
Chris_Kaos
Default Brushless ESC question for hovercrafts
I'd like to go backwards.
Currently, I have no issues, except for that. I'm using a Great Planes Rimfire 300 and compatible ESC, but it has no reverse function.
My question is, can I use a car ESC with a reverse function along with my current motor, or would I have to replace the motor as well?
I was thinking something like this: http://www.hobbyking.com/hobbyking/s...idproduct=7189
Old 06-13-2011, 04:41 PM
iron eagel
iron eagel's Avatar
Default RE: Brushless ESC question for hovercrafts
Nope, should work fine with your motor as long as it carries enough current for your motor.
Edit to add:
I looked up your motor it should work. depending upon the plug setup for the receiver connection.
Old 06-13-2011, 05:12 PM
iron eagel
iron eagel's Avatar
Just one thought...
Unless you are using a separate controller for you lift fan/blower when you reverse thrust it will slam your hovercraft into the ground.
Old 06-13-2011, 07:14 PM
Chris_Kaos
My lift and thrust are controlled indepdently.
Thanks a lot for the help.
Old 06-14-2011, 02:32 AM
charlie111
charlie111's Avatar
I am also looking for 2 escs for 2 brushless motors.Might have to by them used?They are for this electric rotowing design?
