Land yacht build.
Land yacht build.
Well after seeing a few vids online these thins seem fun.
i have no experience in and sail powered rc but I have built various rc cars and trucks .
I love the poly pipe build but it's a little small for my liking.
So here goes my land yacht build.
plans are jut to build and see what it ends up like. Using and old fishing pole section as a mast that will be about 1.75metres tall,
footprint will be about 1.3 x 1 metre. I'm using 1/8 scale buggy wheels an axles to keep it free moving. And to hold it all together I will be building a lightweight aluminium chassis at work.
the rest will just be guess as I build.
any questions will be happily answers if I can.
this is the jig I built today to get it straight .
RE: Land yacht build.
Well had some difficulties fitting th bearings into the custom build hubs I planned to use so dropped
To plan b and used the buggy hubs which will be awkward on the from and less than perfect on the rear
But will function better than the custom ones.
Gonna run some camber on the rear just for looks rather than practicality or handling.
Hubs being built
Mainly aluminium , there is room for ballast inside and at the end of each strut.
id rather add ballast than have it too heavy and sluggish in light winds.
im still thinking about mast size , 1.75 is minimum I think but might go as much as 2 metres !!
Good idea with the weight outboard as far as possible, rather the maybe twice or more weight on the center line. I do not know if this will help you but check this out, save a lot of weight over a round tube. You might think carbon fiber tube also. The weight of the mast becomes real important when it start getting close to the fulcrum point of the base, the less weight the better, meaning less ballast!
http://www.ludwigrcyachts.com/spars.htm
I'm gonna be using a section off a carbon fibre fishing pole as the mast, it probably weighs 30g at most ,
Yet it's super stronger and rigid
Cool, your rigging angle to the mast should never be less the 7°, as although it holds be mast down it has a hard time controlling side to side movement! That is why the have spreaders about 60 -75% up the mast, it opens up that upper rigging angle to regain control! I am probably telling you things you already know, but if you don't it may help!
Nope ! I have no idea on rigging lol , never sail and never owned a rc yacht.
tbh the mast is so strong I may not need to rig It but will probably do it for peace of mind
Simplest rigging would be a pair of stays on each side fixed about 50 to 60% up the mast, or as high as you can go with the 7° rule applying; side to side. On each side the lower point of attachment should be equal distant fore and aft from the mast at ±10°. those four stay will provide good fore and aft, as well as side stability. If you are so inclined to put the top stays on the spreader would go at the same spot as the upper point of attachment of the lower four stay, and only as wide as necessary to comply with the 7° rule! Epoxy a collar around the mast and it will absorb the downward pressures as you DO NOT want to screw into the spar. Almost a given that it would break there especially if you do not put a set of upper stay on. Ice boat some times have s tail boom with a back stay attacked to the same point as the upper stays.
I think I understand what your saying, but might need some extra help when the time comes
But it's good to know someone can help when I need it
Emil me @ [email protected] a sketch with dimensions and I will make you a drawing of the rigging!
Second hub fitted today, that's the whole back end finished, all needs cleaning and the welds neatening up yet but it's pretty much there.
