Unusual R/C Discuss Airships, Blimps, LTA, VTOL, Ground Effect Vehicles, Hovercaft and more.
Single Fan Thrust Vectoring VTOL Project - MonoPhan
Reply
Old 01-17-2019, 05:03 PM
UN.RCONT.OL
UN.RCONT.OL's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Single Fan Thrust Vectoring VTOL Project - MonoPhan
I usually use my existing threads for the new stuff that I build/post but this is kind of a new concept that I am testing. The unit is a first in many ways and is a prototype to test my easy VTOL concept, where I want to harness the lift from a wing without “really” transitioning to horizontal flight in terms of conventional controls and flight characteristics, while flying “almost” horizontally I am also looking for a design which will not be sluggish in vertical flight while creating lift in horizontal (or semi horizontal) flight, without folding wings, etc... Below are some videos from last couple of weeks…
This is my first Mono unit with CG this high with a single battery and with carbon fiber thrust vectoring vanes. The first flight was a failure as result of this and the not enough gyro compensation. So, I made some changes to PID, replaced the backbone supporting piece with a 2mm carbon fiber piece for better support and just in case added this small foam board piece to make sure there is some more lateral resistance. The second flight was successful but still not there. You really need to be on the controls to keep the unit off the ground. Higher compensation levels are necessary. Also, I am not sure if I will be getting as long as hover time as I was hoping. But I have other plans for this unit which will hopefully keep it I the air for much longer times.
This turned out to be a completely different animal. The wings placed at the center of gravity didn't seem to help stabilize the unit. Tomorrow new test with higher CLR and a higher gryo compensation levels...
Testing different wing designs which can handle vertical and horizontal flight. The problem is to come up with a wing design that can handle a stable transition to horizontal flight while handling the pitch and roll vertical flight stability with proper level of lateral resistance. The most successful one for transition was the last one, which is a recycled wing from one of my unsuccessful units years ago. It doesn’t compensate for the roll lateral resistance, which I had to manually compensate during the flight. I will work on that piece…
The last video shows the best result so far. The Unit is now capable of transitioning to horizontal. Need to adjust aerodynamics and the tuning further to harness the most possible lift from the wings.
UN.RCONT.OL is offline
Old 01-19-2019, 07:07 PM
UN.RCONT.OL
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The design is pretty much finalized. It flies amazingly good vertical and horizontal. Still working on getting the baro respond better. I have three settings programmed in the FC.
1- The first one tilts the unit right above around 10 degrees attack angle, avoiding altitude loss at full stick. In this mode, I will use the throttle for altitude control.
2- The second mode tilts the unit below 10 degrees attack angle. In this mode at full stick, the unit will start losing altitude, which makes it possible to fly it almost like an airplane, adjusting the altitude with pitch. I will extend the tilt angle below 0 degrees depending on flight capabilities.
3- The third mode will not go lower than 25 degrees attack angle and will activate the altitude hold. This will be the economy mode, where I will harness the lift from high attack angle wings and the unit will automatically adjust the throttle down and the lift kicks in and it starts climbing. I will adjust this attack angle to get the best flight time based on testing.
Looking forward to get some onboard videos and post.
Old 01-23-2019, 06:52 PM
UN.RCONT.OL
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The design is finalized and the test cardboard surfaces are replaced with the new ones. I cannot believe the unit turned out to be such a good flyer. This is just a slow test flight to make sure all new stuff works. The unit loves transitioning to horizontal and speed up. Hopefully, new videos coming soon...
Old 01-28-2019, 06:11 PM
UN.RCONT.OL
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It was a good test after a tough weekend. The yaw was unresponsive in horizontal flight all through weekend. So, I tested some additional surfaces and took off the stabilizer to let the nozzles handle better. Didn’t work. After studying for ours how the nozzles react at lower attack angles, I was able to fix the tuning and realized that I wasn’t piloting the craft correctly.
This video consists successful transitions and long stretches of horizontal flight with maneuvering. The flight is not as smooth as I wanted because of lack of rear stabilizers. So, I will add some new stabilizing surfaces at the back and test the results. I believe the unit will be able to handle attack angles down to minus 10-15 degrees which should be more than enough for some high speed dives. I don’t think the FC is capable of handling anything less than that.
Old 02-10-2019, 06:31 PM
UN.RCONT.OL
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After working on the final design changes, at last was able to start testing the baro assisted semi-horizontal flight to calculate the increase in efficiency, the reason that I built this unit for. This flight is 100% baro assisted (except take off and landing). I circled around the park without any major throttle intervention and let the unit adjust the throttle, keeping a constant altitude. I calculated around 20-25% increase in the efficiency of the unit. Which is better than nothing, less that I expected. I will test some different attached angles and see if I get anything better. I think I need to cruise with a higher speed that I am currently testing for better efficiency.
https://www.youtube.com/watch?v=YU6sE19W36M
