Unusual R/C Discuss Airships, Blimps, LTA, VTOL, Ground Effect Vehicles, Hovercaft and more.
RC Hovercraft build
Reply
Old 11-26-2008, 10:44 PM
jonathanhly
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RC Hovercraft build
ok so i have losts of spare electic airplane parts and hover craft are just soo cool. ive tried before but have failed []
so i come to the experts
basiclly it would be small maybe 15x5 inches, two electric motors, one with a fan pointing down, i want a bag type skirt, either one with the wholes in it, or one that has no outlet and is fed by small channels the open near the fan outlet, while the rest of the air is pushed down to the center with the inflated bag surrounding it. if that makes any sense?
i used a thick plastic material last time that worked really well, so ill use that again. The base of the craft was plastic which seemed to work well.
and finally i have a rc car motor that i would use to propel the craft for and aft, i have a three blade prop which i can mount to it, and it would also have ofrward and reverse (really cool)\
and lastly a servo stolen from a car to opperated to rudders mounted behind the fan unit.
fairly simple it may seem
but it is hard work!
any info on how to make easy skirts would be awsome.
i can handle everything else easily
i just want the skirt to handle everything tile, brick, dirt, grass, water, gravel and such but to also be easy enough to make a new one if needed. if i can i will post a picture of what i already have,
jonathanhly is offline
Old 12-06-2008, 03:32 AM
hover Tim
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: RC Hovercraft build
IT nice to see someone haveing a go with hovercraft size may be a bit of an issue though as bigger is better wiht hovercraft the smallets craft i have got is 600mm long and the largest on is aboiut 4 foot long everyone sturggles with the skirt so you may find this info useful http://www.rc-hovercraft.co.uk/infoframes.html and click on skirt calculator with regards to performance your craft will run on tiles no problem it will only run a very short grass probably not bricks and water should not be a problem the above link will show you how to make a bag skirt what sort of skirt were you after
hover Tim is offline
Old 01-09-2009, 10:39 PM
Love2FlyMN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just put pics of mine up...I haven't yet mastered the skirt part of it but I'm going to keep trying to find something that I can drive on water. My thread is a couple up from here
Love2FlyMN is offline
Old 03-03-2009, 12:26 AM
Swazzi2000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check out mines. Its not a scratch kit but it may give u some ideas on how you can build yours... Let me know if you have any questions...
ID:	1149072   Click image for larger version
ID:	1149073   Click image for larger version
ID:	1149074   Click image for larger version
ID:	1149075   Click image for larger version
ID:	1149076   Click image for larger version
ID:	1149077   Click image for larger version
ID:	1149078   Click image for larger version
Swazzi2000 is offline
Old 04-15-2010, 06:01 PM
Andersean
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i just built one from scratch andi need a skirt first and foremost and some sort of watertight shell (i plan on using it on water) any advice?
Andersean is offline
Contact Us Archive Advertising Cookie Policy
